Just wanted to share what happens to your timing bearings when they fail
This is the new bearing...
picture.php?albumid=223&pictureid=2166
This is the old bearing
picture.php?albumid=223&pictureid=2167
And this is what I looked like when I saw the bearing
picture.php?albumid=223&pictureid=2170
:lol:
More pictures for you picture hounds
picture.php?albumid=223&pictureid=2168
picture.php?albumid=223&pictureid=2169
picture.php?albumid=223&pictureid=2171
picture.php?albumid=223&pictureid=2172
And sorry for the fuzzyness of the pictars.
The camera was too complicated for me to get all the settings right before
each picture
Twitch
This thread shows two examples of why it is good to change your timing belt idler pulleys when replacing the timing belt. Yeah you might save a few $$ when changing the timing belt by not changing them but if they fail before you change the timing belt again, you will spend even more $$$$.
How many miles on them?
These came off Xandra. and her engine had around 250k, unless they were
replaced with the engine swap that was performed at 90k for the engine,
which I seriously doubt.
I didn't even replace them when I redid the top end of the engine.
And a little Bio on Xandra, she's a 90 body with a 91 engine and a 94 tranny.
This is what happens when one of those ball bearings gets lodged in the race and locks up....
http://www.main.experiencetherave.com/subaru/images/shreddedtbelt/
:eek:
That practically happened to Zeh Vagon, but it only ate a few teeth off.
Twitch
Edited by Twitch de la Brat
Forgot Details
my former 94TW had this happen to the nice person i sold it too. Also, his main crank pulley decided it wanted to commit suicide same time too.
If anybody services an engine, inspect for any wear at all, and replace with new or you are taking a big chance.
Well, it all went together nicely and I got it timed on the first try :banana:
And what I believe had happened was the bearings failed soon after I redid the
heads and the outer race just rode on the inner race until it wore to the point
the belt lost tension and the bearing started to make the belt bind against itself.
I'll take pix of the back of the belt.
Its burnt, cracked and bubbled.
So the belt would've failed within, probably another 10k if not 5k.
Twitch
