dgarlepp Posted March 9, 2010 Share Posted March 9, 2010 Hi, I have a 1995 Legacy AWD 2.2. Need to know which model years 2.2 will bolt right in. Will a 2.2 in a 1990 fit? Did they use the same exact 2.2 for a bunch of years? The crankshaft pulley bolt came lose and damaged the crankshaft key. Is the key replacable. Thanks for any help. Link to comment Share on other sites More sharing options...
davebugs Posted March 9, 2010 Share Posted March 9, 2010 EGR or not? (auto or stick). I'm thinking no on the '90 but I don't know. I usually stick to 95-99's. Someone else here should know or point you to a chart or previous thread thought. Link to comment Share on other sites More sharing options...
subaru360 Posted March 9, 2010 Share Posted March 9, 2010 Is your 95 a 5 speed or automatic? If it's a 5 speed the 90 engine will work as long as you transfer the intake manifold and all the sensors over from your old engine. If it's an automatic, you need a 95 2.2 automatic engine for a direct fit. Or a 96-98 2.2 automatic engine if you can get the matching single port exhaust y pipe. You can replace the crank key, but usually the end of the crank gets damaged when they come loose. Link to comment Share on other sites More sharing options...
bobaru Posted March 9, 2010 Share Posted March 9, 2010 Is your 95 a 5 speed or automatic? If it's a 5 speed the 90 engine will work as long as you transfer the intake manifold and all the sensors over from your old engine. If it's an automatic, you need a 95 2.2 automatic engine for a direct fit. Or a 96-98 2.2 automatic engine if you can get the matching single port exhaust y pipe. You can replace the crank key, but usually the end of the crank gets damaged when they come loose. But aren't 90 though 94 2.2 dual port heads..........95 and up 2.2 single port heads Link to comment Share on other sites More sharing options...
Rooster2 Posted March 9, 2010 Share Posted March 9, 2010 Hi, I have a 1995 Legacy AWD 2.2. Need to know which model years 2.2 will bolt right in. Will a 2.2 in a 1990 fit? Did they use the same exact 2.2 for a bunch of years? The crankshaft pulley bolt came lose and damaged the crankshaft key. Is the key replacable. Thanks for any help. I had a 91 that it too had the crankshaft pulley bolt come loose and damage the key. It looked really chewed up, but was repairable by a shop. Suggest doing a search on this forum. There is quite a bit previously written about this problem, and how to fix it. Link to comment Share on other sites More sharing options...
subaru360 Posted March 9, 2010 Share Posted March 9, 2010 But aren't 90 though 94 2.2 dual port heads..........95 and up 2.2 single port heads No, 96 and up is dual port heads. Link to comment Share on other sites More sharing options...
Mike104 Posted March 9, 2010 Share Posted March 9, 2010 I found this on a Miata forum with similar crankshaft keyway issues: http://www.miata.net/garage/hsue/Softtop.htm Just an idea Link to comment Share on other sites More sharing options...
bobaru Posted March 9, 2010 Share Posted March 9, 2010 No, 96 and up is dual port heads. Thats funny I got a feb 96 OBW 2.2 single port. Link to comment Share on other sites More sharing options...
idosubaru Posted March 9, 2010 Share Posted March 9, 2010 Pretty sure he just had a typo there, he knows. 95 is dual port. 96+ is single port. Damaged crankshaft should be repaired, not replace the entire engine. I've fixed a few in my garage. The keys I believe aren't even necessary if you bolt the snot out of the crank pulley, I've done it a bunch of times, but I know what i'm doing, not trying to just turn, flip, make a quick buck. A competent shop can repair it. Worst case, take the entire engine to a machine shop, they can do anything with metal and will certainly repair it for less than the cost of another engine. An EJ18 will work as well in your 95 legacy. My EJ18 swapped legacy does fine in flat lands. The mountains make it downshift a lot but it would be great in Florida if you're not worried about performance. An EJ25 would be plug and play too. Link to comment Share on other sites More sharing options...
dgarlepp Posted March 9, 2010 Author Share Posted March 9, 2010 Thanks guys, great info. I was hoping to just get a new pulley (it got most of the damage) and bolt it on real tight to the crankshaft. I could use lock tight. Whats the most torque I can give the bolt? Link to comment Share on other sites More sharing options...
dgarlepp Posted March 9, 2010 Author Share Posted March 9, 2010 It's an automatic, it's a right hand drive for postal also. I use it to deliver mail. And I need the AWD for the deep sandy roads down here. I forgot to ask how to replace the key. Link to comment Share on other sites More sharing options...
johnceggleston Posted March 9, 2010 Share Posted March 9, 2010 It's an automatic, it's a right hand drive for postal also. I use it to deliver mail. And I need the AWD for the deep sandy roads down here.I forgot to ask how to replace the key. search 'crank pulley repair' there are several good threads to read, including this one: http://www.ultimatesubaru.org/forum/showthread.php?t=108471&highlight=crank+pulley+repair http://www.ultimatesubaru.org/forum/search.php?searchid=964612 Link to comment Share on other sites More sharing options...
subaru360 Posted March 10, 2010 Share Posted March 10, 2010 I forgot to ask how to replace the key. Get underneath it with a chisel and pop it out. Tap the new one in with a hammer. Link to comment Share on other sites More sharing options...
idosubaru Posted March 10, 2010 Share Posted March 10, 2010 if it's really bad i've never even bothered to install a key, they actually aren't necessary. i'm not saying i recommend that and i realize the importance of a key - but if you know what you're doing it's not worth expensive repairs or replacing an engine when this works. it's an iron crankshaft and enormous iron 22mm bolt, i've never stripped one with my 3 foot pipe put over my socket wrench. do that and it's not coming off, i've never even used locktite. Link to comment Share on other sites More sharing options...
dgarlepp Posted March 11, 2010 Author Share Posted March 11, 2010 thanks, the key isn't that bad. Just rounded a little on one side. Theres a 1990 AWD auto Legacy in my local junkyard. Will the crank pulley work on my 95?? Thanks again Link to comment Share on other sites More sharing options...
subaru360 Posted March 11, 2010 Share Posted March 11, 2010 Yes the pulley will fit. Link to comment Share on other sites More sharing options...
