Skipper47 Posted February 12, 2004 Share Posted February 12, 2004 Title says it all. On a 94' Loyale I know for a fact that they came standard with Manual Trannys. Unfortunatly for me the original owner was a older woman who wanted a 3 spd auto. I was curious if it was anyway possible to convert over to a 5spd. Is there any websites with detailed info on how to run a clutch pedal, install stick shift, and I figure I have to keep the Auto Shift on the fly 4x4 since I noticed some manuals have the push button instead of another stick. SO I was wondering how difficult this could be? Link to comment Share on other sites More sharing options...
jdemaris Posted February 12, 2004 Share Posted February 12, 2004 Seems your best bet is to get a cheap junker with all the parts you need. I've got over a dozen Loyale 4WD wagons in my field, some auto and some with 5 speed. All ran fine when taken off the road, just rusted out so bad they couldn't be driven any further. I'm in Central New York State, and usually what happens with the Loyales is the rear spring towers rusts out, the spring comes through inside the car - and it's all over. Link to comment Share on other sites More sharing options...
WJM Posted February 12, 2004 Share Posted February 12, 2004 its pretty easy to do. Ive done the 2wd auto to 5spd FT4WD conversion...as per my sig says. Link to comment Share on other sites More sharing options...
83projectbrat Posted February 12, 2004 Share Posted February 12, 2004 im also for this in my 89 wagon, with a 3 speed auto. i have a 85 gl wagon 5 speed dual range. everything work good there ? in the 89? also what about the comp. and stuff if i go to maunual will the car still start and not think its in drive or somthing matt Link to comment Share on other sites More sharing options...
WJM Posted February 12, 2004 Share Posted February 12, 2004 there was some wiring issue with mine, due to that fact i wanted to use cruise control. I have one push button switch that i can use to disable the starter, and engage the CC...and ive also had to make the computer think its in drive all the time to i can use CC. i dont know about the wiring on an 89 tho...something similar i bet. And yes, everything will physically bolt up. Link to comment Share on other sites More sharing options...
Skipper47 Posted February 12, 2004 Author Share Posted February 12, 2004 Is there any websites on explaining the tranny swap? Link to comment Share on other sites More sharing options...
Turbone Posted February 12, 2004 Share Posted February 12, 2004 http://usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f50d9b8.15492800/&FileType=Article&File=ARTICLE_3f29b750a92b88.77574552.art Altho its from older to newer, the principals are the same. There will be some electrical issues, but I dont know of anyone else doing this conversion. Link to comment Share on other sites More sharing options...
MilesFox Posted February 12, 2004 Share Posted February 12, 2004 if the trans comes with the mechanism, get all the vac lines and wires that will come with it. i think you could find away to use the at's vac source if youre creative not only that, you have to bypass the neatral safety, its in the console, jump a wire. i forgot which wires, but i picked a wire and jumped the other s one by one, the prndl on the dash would lite up whatever, until i jumped one till the key turned over you will also have to wire up the reverswe light Link to comment Share on other sites More sharing options...
