Steve's AWESOME Brat
Splinter
On the offchance that anyone cares, it was the pickup coil. Just tested it with a multimeter, 680ohms from wire to wire and the yellow wire is grounded to the body.
Weird that it would just suddenly fail like that though...
  Splinter said:
Guys, the car doesn't run. At all. The tach moves with the engine SHUT OFF.
How can the shaft possibly be moving around causing the tach to bounce when the motor isn't turning?
someething with the alternator or charge system failed. I had a alternator voltage regulator go bad, and a turn of the key would send the tach needle to like 3000 room without even kicking the starter on. Wipers would move around, even though the switch for them was off....
Edited by bheinen74
It's a single wire alternator, reg doesn't even see the rest of the car. I tried unhooking it, didn't change anything. Unhooked the dizzy, no more tach bounching :)
It failed an ohm test, it's grounded to the casing, I'm fairly confident it's the dizzy pickup coil at this point
Edited by Splinter
  • 3 months later...
Yea, the only reason it survived at all was it was mostly garage kept.
So I'm having some pretty weird electrical problems. The lowbeams on the car work normally, but when you put the high beams on each bulb only sees 6 volts instead of twelve so they're super dim (confirmed with a multimeter)
Also, on the right side only, there's some significant problems with the tail lights. With the lights on and the indicator on, the indicator and brake light alternate flashing, same if you put the reverse lights on. With the other lights off, it just flashes very fast and dim. The only ground I could seem to find was in the bed just behind one of the access panels. I cleaned it up and it didn't seem to make a difference. I've been searching for an answer for a few days so far and been pouring over the wiring diagrams but so far nothing.
Any ideas?
There is a wiring connector behind that rearmost panel, check to see if there is any corrosion there. It is the last connection before you get to where the wiring harness splits to go across the back of the BRAT to feed the Driver's side lights.
Bad ground for the rear lighting can cause all sorts of wierd lighting issues.
Any ideas?
  • 2 weeks later...
Cleaning that ground helped some, thanks. Still some weirdness with the flasher speed but at least people can see I'm indicating now thanks.
On another front, here's the parts car I was given:
3 hours pass...
Monday we pull it out of there to remove the powertrain. Unfortunately I didn't notice the damage on the passenger side fender before, which is the same fender that's damaged on my brat. Damn. Oh well, I still got lots of good parts like a non-rusty cowl, shiny wiper arms and a 4MT swap!
The round headlight it only there because the front end was gone and the previous owner was using it as a bush vehicle and needed something for a headlight. The passenger side under the door almost collapsed when I sat on it due to rust. Yikes. This car was a gonner for sure.
  • 2 weeks later...
Yea I think I'm going to put a little more juice into the torsion bar (It's still got lots left, and I have a spare if I break it) and give some abuse in a controlled environment to make sure it's all ok before I drive it on the street.
  • 9 months later...
