XT Question
Looking for some info on a subie xt...I'm looking at a car for sale that is said to be a 1987 Subaru XT Turbo, and that's what it is but there are some things I found to be odd for that year and model. It is a Trubo XT full-time four/all-wheel drive automatic with the air suspension and a GL-10; it has the auto sealtbelts. I didn't think the auto belts showed up until 89 and that full-time four/all-wheel drive was only on the XT-6...anyone out there who can help out?:confused:
hi, i think that trans did come out in the 87-1/2 version, not sure on the seatbelts, ithought that was in 88 but the late 87 could have.
just code the vin number , that is easy and if the door jam one is in question the one underhood is stampped in the body, can't change that one.
EA82T's aren't worth much. Most undesireable Subaru engine.
The inoperable air suspension is a common problem. The best solution is to just swap the struts for standard one's.
With a bad rear bumper and needing struts all around..... 23 y/o car with an undesireable engine.... automatic (yuck)...... less than $1000.
Run.
Yeah it's not worth much, they'll be very hard pressed to get more than $1,000 for that car.
The rear bumper can come off any 1988+ XT or XT6.
Air suspension should be converted to coil overs any way so I don't consider that a big deal.
