mountaingoatgruff Posted March 14, 2010 Share Posted March 14, 2010 85 Brat 92 ECM & harness 97 EJ22 Finally got to the point where I tried to crank and it turned over but I had no CEL and no fuel pumping - like the MPFI system isn't coming on. I checked over my wiring again and found only 1 mistake: I had put constant 12V to the MPFI diode instead of ignition switched 12V. I've fixed that, verified I have voltage at the ECM & ignition relay, checked all my grounds and tested the ig relay and fusible with a multimeter. ECM came from the junkyard but I have yet to get a bad one. I'm not sure how to see if this one is toast or what else to check. Link to comment Share on other sites More sharing options...
Blacky Posted March 15, 2010 Share Posted March 15, 2010 I'm thinking the ECM is not compatable with the motor. 92 was way before OBDII and a 97 engine would definately be OBDII. They just aren't communicating with each other properly. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 15, 2010 Author Share Posted March 15, 2010 I'm thinking the ECM is not compatable with the motor. 92 was way before OBDII and a 97 engine would definately be OBDII. They just aren't communicating with each other properly. 97 longblock, 95 intake, 92 ECM & harness I put a 92 TB on there (for the TPS) and 92 cam/crank/knock sensors. I'm using a 92 MAF and will be using 92 O2 sensor. I wired in the 97 coilpacks, common upgrade. Everything that matters is OBD I. There should be no compatability issues, none that would cause this scenario at least. Link to comment Share on other sites More sharing options...
Blacky Posted March 15, 2010 Share Posted March 15, 2010 You say no fuel is pumping. Is the fuel pump fuctional? Link to comment Share on other sites More sharing options...
Gloyale Posted March 15, 2010 Share Posted March 15, 2010 Check both the yellow wires going to the Ig. Relay and make sure they have power. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 15, 2010 Author Share Posted March 15, 2010 You say no fuel is pumping. Is the fuel pump fuctional? It was feeding the SPFI engine in there weeks ago just fine. Link to comment Share on other sites More sharing options...
capn_r Posted March 15, 2010 Share Posted March 15, 2010 Are you maybe dealing with different generation cam sprockets that is creating some kind of incompatability with the cam sensor? Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 15, 2010 Author Share Posted March 15, 2010 Check both the yellow wires going to the Ig. Relay and make sure they have power. Both have 12V from the battery. I verified I have 12V out the other side when the relay is on and I have full power at the ECM connectors: constant 12V to B48 pin 15 (back-up power) 12V in run & start to B48 pins 2 & 13(power supplies) 12V in run & start to B58 pin 12 (ignition switch) 12V in start only to B56 pin 10 (start signal) Gounds have good continuity, voltage is there...:-\ Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 15, 2010 Author Share Posted March 15, 2010 Are you maybe dealing with different generation cam sprockets that is creating some kind of incompatability with the cam sensor? Even if I were I think I'd have a CEL and fuel pumping right? I'll see if I can find tone patterns. Link to comment Share on other sites More sharing options...
Gloyale Posted March 15, 2010 Share Posted March 15, 2010 Even if I were I think I'd have a CEL and fuel pumping right? I'll see if I can find tone patterns. Yeah, youd have CEL and Fuel Pump operation for at least a moment. Plug in the test connectors, does the fuel pump cycle? One thing I did mistakenly on my first swap is I wired the output to the fuel pump from the relay.........directly to ground:eek: It's a black/red wire......all the other black wires in the swap are grounds and I mistakenly thought that wire was the FP relay ground. "Yeah......the Black/red wire from teh relay is POWER, not ground.....note to self." Sorted it out and it was fine. Link to comment Share on other sites More sharing options...
baccaruda Posted March 15, 2010 Share Posted March 15, 2010 When I did my wagon's EJ swap, I couldn't get it to start until I swapped ECMs. I don't remember what part of the system wasn't working. Get another one and see what happens if you swap them; you can always return the extra if it turns out not to be the cause. Link to comment Share on other sites More sharing options...
Numbchux Posted March 15, 2010 Share Posted March 15, 2010 Ah the joys of a swap cobbled together from numerous cars with unknown history. It could be many things, the ECUs are pretty tough to fry, but not impossible. If you've got a spare, try it. but I'd pin out every wire before buying one. Link to comment Share on other sites More sharing options...
Yo'J Posted March 16, 2010 Share Posted March 16, 2010 You could plug yours into a known running car, I don't know if Id try it the other way though. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted May 30, 2010 Author Share Posted May 30, 2010 I replaced the ECM, re-ran all MPFI power through a hidden toggle switch, added some grounds under the dash and now it runs beautifully. The previous ECM will not turn on so it must have gotten fried at some point. Exhaust and radiator work to come soon...been spending too much on the Ramcharger... Link to comment Share on other sites More sharing options...
