monstaru Posted March 15, 2010 Share Posted March 15, 2010 so, i havna dissappeared, i have just been plugging away with all of the boring stuff.like this, and some other small things. this is the samurai transfer case crossmember....... it is mounted in the frame now............. cheers, brian Quote Link to comment Share on other sites More sharing options...
Pooparu Posted March 16, 2010 Share Posted March 16, 2010 hmmmmm.... Quote Link to comment Share on other sites More sharing options...
mcbrat Posted March 16, 2010 Share Posted March 16, 2010 if you plan on hooking a speedo up to the sami t-case, you need to watch for that... the way mine is clocked, and how the cradle fits, it was a tight fit, and it comes out of the bottom of mine almost.... I had to use a sami cable for the length, but it fits right into the back of the soob cluster, so you can at least accurately calc your speed... Quote Link to comment Share on other sites More sharing options...
monstaru Posted March 16, 2010 Author Share Posted March 16, 2010 (edited) where i am going , i will not need speedometers, maybe a slowometer....but definitely not a speedometer..... it'll be more fun to keep it hooked to the 5 spd, and do 75mph when really moving 2mph....:lol:cheers, brian if you plan on hooking a speedo up to the sami t-case, you need to watch for that... the way mine is clocked, and how the cradle fits, it was a tight fit, and it comes out of the bottom of mine almost.... I had to use a sami cable for the length, but it fits right into the back of the soob cluster, so you can at least accurately calc your speed... Edited March 16, 2010 by monstaru Quote Link to comment Share on other sites More sharing options...
Uberoo Posted March 16, 2010 Share Posted March 16, 2010 set it up to read in inches per minute.that way it "looks" like your going fast... Quote Link to comment Share on other sites More sharing options...
