1998 outback heater temp control cable
Hi,
I have a 1998 legacy outback wagon and the temp control cable has come of where it attaches to the door below the glove box. I’m trying to figure out if there is a cable holder of some kind down in that area or do you think it has come off the clip that holds the cable on the back of the control box? If I can fix it without pulling out the heater control box that would be nice. Any thoughts would be much appreciated.
There is a little metal spring clip that the cable is held by. If you see the c-clip on the cable, it goes against the spring clip. Its black steel about 3/4" long and rounded to fit the cable with a little tab on it to use to open it up.
No need to remove anything, just look up there and you should see it.
