kanurys Posted October 5, 2012 Share Posted October 5, 2012 The fuel gauge wiring shouldn't be too hard if you have one from the impreza and the one from the GL. I think the Impreza is a two part gauge in series. I'm not sure about the GL. I'll look at the diagrams and see what needs to be done. What year impreza and GL, again? I assume the GL was originally carbed? You might want to swap in the FI tank off of an EA82 since it has bigger ports and surge baffles. If you have all the level sensors talked about above, could you measure the resistance of each in their max and min positions? I'll come up with a circuit to mimic the EJ stuff and you can hook it directly to the EA stuff... Kind of plug and play if you know where your wires all go. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 5, 2012 Author Share Posted October 5, 2012 The fuel gauge wiring shouldn't be too hard if you have one from the impreza and the one from the GL. I think the Impreza is a two part gauge in series. I'm not sure about the GL. I'll look at the diagrams and see what needs to be done. What year impreza and GL, again? I assume the GL was originally carbed? You might want to swap in the FI tank off of an EA82 since it has bigger ports and surge baffles. If you have all the level sensors talked about above, could you measure the resistance of each in their max and min positions? I'll come up with a circuit to mimic the EJ stuff and you can hook it directly to the EA stuff... Kind of plug and play if you know where your wires all go. The Impreza harness is from a 01 RS. The GL is 87 and was fuel injected. I noticed the fuel pump wires are just hot and ground, so that is cake. But the rest goes to the tank sending unit and smog stuff. At this point I dont have any of the 01 smog stuff so I just want to figure out the fuel guage. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 6, 2012 Author Share Posted October 6, 2012 Spent a few hours at the shop today and with the help of a friend moved some cars around. More importantly moved my gl back into the shop Now it is out of the elements and I can work on it again after hours!! Link to comment Share on other sites More sharing options...
bratman18 Posted October 6, 2012 Share Posted October 6, 2012 Nice, I look forward to seeing progress Link to comment Share on other sites More sharing options...
kanurys Posted October 6, 2012 Share Posted October 6, 2012 The Impreza harness is from a 01 RS. The GL is 87 and was fuel injected. I noticed the fuel pump wires are just hot and ground, so that is cake. But the rest goes to the tank sending unit and smog stuff. At this point I dont have any of the 01 smog stuff so I just want to figure out the fuel guage. I plan on making a dummy box to plug the fuel tank temp/pressure/vent ecu wires into. It will be for a phase II EJ engine, so it should be the same for yours. I could combine those with the fuel level conversion once I know they work on my rig. I can make the fuel level converter adjustable so you can fine-tune it to make the gauge work right. Is this something you want to pursue (in the future)? You probably just want to get it running, for now... Link to comment Share on other sites More sharing options...
JacksonRally Posted October 7, 2012 Author Share Posted October 7, 2012 I plan on making a dummy box to plug the fuel tank temp/pressure/vent ecu wires into. It will be for a phase II EJ engine, so it should be the same for yours. I could combine those with the fuel level conversion once I know they work on my rig. I can make the fuel level converter adjustable so you can fine-tune it to make the gauge work right. Is this something you want to pursue (in the future)? You probably just want to get it running, for now... Yes please! I want to do it all and right the first time. Link to comment Share on other sites More sharing options...
kanurys Posted October 7, 2012 Share Posted October 7, 2012 I predict I'm going to be spending some quality time with the fsm's. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 7, 2012 Author Share Posted October 7, 2012 It sounds like I will still be able to get the car up and running with out the other stuff.....correct? I just need fuel pump. I know with out the rest I will have a CEL but that wiring will be easy to access. I tossed out my old carpet because it was pretty beat. Punch list to get her up and running *fill hole in firewall to finish hooking up a/c lines *mount radiator and a/c condensor *fabricate new duct work under dash *do final lay in of wiring harness under dash *make final wiring splices Fire it up and see what I did wrong Then I can more or less do final assembly My goal is to go snow wheelin on January 1st! Link to comment Share on other sites More sharing options...
kanurys Posted October 7, 2012 Share Posted October 7, 2012 Yeah, the fuel temp, pressure and vent codes won't throw it into limp mode. If you can't rev over 4500rpm you're most likely in limp mode and need to deal with another code... good luck. Oh, and get me those resistance readings, when you can. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 9, 2012 Author Share Posted October 9, 2012 I built the filler box piece for the firewall. Still need to weld it. Next is to cut new holes for the harness to go through the firewall into the engine bay. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 9, 2012 Author Share Posted October 9, 2012 Kanurys, do you have an online source to find some wiring info on my 01 harness? I went through the GL stuff before disconnecting the battery to log what the headlight, hi-beams, tail lights....etc but dont have that info on the 01 harness. Link to comment Share on other sites More sharing options...
kanurys Posted October 9, 2012 Share Posted October 9, 2012 (edited) Kanurys, do you have an online source to find some wiring info on my 01 harness? I went through the GL stuff before disconnecting the battery to log what the headlight, hi-beams, tail lights....etc but dont have that info on the 01 harness. try this site: http://jdmfsm.info/Auto/Japan/Subaru/Impreza/2001/ look at the bottom three pdf's... As far as I know, the headlight relays are in the Main Fuse Box that is under the hood (the one you put in place of the EA82 coolant overflow reservoir). They're next to the A/C relay and the fan relays. You'd just need to hook the headlights to those and ground them... Or custom wire them up. Edited October 9, 2012 by kanurys Link to comment Share on other sites More sharing options...
JacksonRally Posted October 10, 2012 Author Share Posted October 10, 2012 Awesome, thanks for the link. Now I just need my 6 year old laptop to show me the goods! Its a little slow these days. I really need to figure out whats up with some cut wires. There is a large flat wide blue plug with all of the wires cut (I would take a pic and show you but again my laptop is not letting me upload photos...yay). Im almost certain that they were for abs stuff but would like to know 100%. Link to comment Share on other sites More sharing options...
kanurys Posted October 10, 2012 Share Posted October 10, 2012 I thought all abs connectors were either yellow or pink. Blue might be the junction between the dash harness and the rear chassis harness... anybody? Link to comment Share on other sites More sharing options...
JacksonRally Posted October 10, 2012 Author Share Posted October 10, 2012 I thought all abs connectors were either yellow or pink. Blue might be the junction between the dash harness and the rear chassis harness... anybody? The plug is on driver side under dash. I think it maaaay be a interior dash harness to engine bay connection? In other news I just ordered some Raychem adhesive lined heat shrink to give my headlight splices a good chance at surviving the elements. I also ordered some adhesive lined heat shrink end caps for items such as abs and airbag wiring. I am just going to cut off plugs and cap the loose ends. I am NOT going to pull all those wires through the harness to trim the fat. So these little end caps should be perfect. Link to comment Share on other sites More sharing options...
kanurys Posted October 10, 2012 Share Posted October 10, 2012 that rings a bell Link to comment Share on other sites More sharing options...
JacksonRally Posted October 10, 2012 Author Share Posted October 10, 2012 that rings a bell Pure genius!!! Ugghhh my memory must be on its way out. I just went back to page 13 of my thread and duh!!!! I did take out the abs stuff just from the engine bay. I think I just left that plug inside to keep remind myself what I did. HAHA that didnt work. Ok now thats solved. I hate working on a project for a year here and there. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 11, 2012 Author Share Posted October 11, 2012 Got a fair amount of work done yesterday. I final mounted the harness under the hvac, ran the wiring through the firewall and hooked a few things up. Then started to pre-fit dash. Next is to make the new vent tracks for the dash. Link to comment Share on other sites More sharing options...
kanurys Posted October 11, 2012 Share Posted October 11, 2012 (edited) Where will you put the computer? I was going to put mine on the floor in its stock position, i was convinced to put in up high in the dash above the glove box so I wouldn't dunk it if I got in the water... Edited October 11, 2012 by kanurys Link to comment Share on other sites More sharing options...
JacksonRally Posted October 11, 2012 Author Share Posted October 11, 2012 Mine is going up high. I wont have a real glove box anymore because of the 01 hvac unit. Im thinking it will be right behind the glove box door. At least I will have easy access to it. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 14, 2012 Author Share Posted October 14, 2012 I managed to get a few cut wires all sealed up and tucked away. Mostly abs wheel speed senor wires and fog lights. They are sealed up with adhesive lined shrink caps and tucked away into the harness in case I need them for what ever reason on some rainy day. From there I figured it was time to see if I can sort out the wiring to the ignition. I am keeping the GL column and ignition key and using 01 light, blinker and wiper switch deal. First I removed the GL light, blinker and wiper switch assembly to see how I could mount the 01 stuff. I have the 01 column with the switches too. I removed the 01 stuff then cut the bracket off the 01 column to see what would work from there. It looks like I can drill some holes and bolt the 01 bracket to the GL column which has some threaded holes, this ended up working out perfect. Now to the ignition....the GL has 5 wires coming out of the cylinder and 5 going to the connector. The 01 stuff has 5 wires coming out of the cylinder and 4 going to the connector, so all Im going to do is join the wires on the GL to become a 4 wire connection and plug into the 01 harness. Im hoping to do this tomorrow to see if I can turn the key and see what comes to life. Im not ready to fire the motor, I just want to see if I have power...etc. Link to comment Share on other sites More sharing options...
bratman18 Posted October 14, 2012 Share Posted October 14, 2012 Sounds like quite the custom project. Post some pics if you can. Link to comment Share on other sites More sharing options...
JacksonRally Posted October 14, 2012 Author Share Posted October 14, 2012 Sounds like quite the custom project. Post some pics if you can. Yeah Im picture posting challenged at the moment Link to comment Share on other sites More sharing options...
kanurys Posted October 14, 2012 Share Posted October 14, 2012 Nice work. The ignition stuff is really straight forward. I'd love to see pictures of the column switches you retrofitted. Also, I just got a bunch of parts in the mail and am ready to make a fuel gauge converter if you have the resistance measurements. Was the rs25 a single or dual fuel level sender vehicle? SK Link to comment Share on other sites More sharing options...
bratman18 Posted October 14, 2012 Share Posted October 14, 2012 Yeah Im picture posting challenged at the moment Yeah I hear ya. I have send picture messages from my cell phone, to my email, and then upload them to photobucket. It's a pain. Link to comment Share on other sites More sharing options...
