I recently bought a used 97 impreza outback sport and am trying to determine if it has a keyless entry system installed (it did not come with a remote). i don't know where/what i should be looking for. if it turns out to not have it installed would it be best/possible to use an aftemarket system or do i need the oem?
Look up under the drivers dash. The keyless from Subaru is a 4x5x1" black plastic box.
If you have power locks you can put one in. If you don't have power door locks you will need an aftermarket kit.
thanks, i just checked it and it looks like i don't have one. i do have power locks though. what would you recommend as far as going with the oem or aftermarket kits. how tricky is the install?
