Wheel Bearings ea82/81 swap.
The front wheel bearings are the same for EA81 and EA82 but the inner seal is different.
If the set of bearing that you are referring to are already in a knuckle, getting them out without damaging the bearings maybe challenging.
Rear's are completely different.
The bearings are like $5 to $10 each. And you aren't going to remove them without damageing them. You have to press on the inner race to remove them from the knuckle and that transmits the force through the balls - basically destroying the bearings.
