My 99 Forester is showing code: PO440. [...]
First take a look at http://endwrench.com/images/pdfs/Foresterinfo.pdf
If that's not the cause, then a common problem is rust through of the gas tank fuel filler pipe.
It can be a rather small hole.
If not that, see:
http://www.endwrench.com/current/02SpringInsiderInfo.pdf
http://endwrench.com/pdf/fuel/MoreP0440TipsInfoW00.pdf
