99 impreza outback sport
bkowens2
The outback engine is a Phase I DOHC.......the Impreza enigne is a Phase II SOHC
Won't work without some mix and match o wiring........and even then there are gonna be issues with the IAC.
Not a direct swap
the outback that i have is a sohc not sure what the 2.5 is havent gone and looked at it yet if they are both sohc will it go smoothly
You have an Outback Sport? (Impreza Outback?)
I was confused. I always think of "Outback" as meaning Legacy Outback. A 99 Legacy Outback will have a DOHC engine.
If both Motors are Phase II then you should be direct fit , or at worst should able to simply swap your intake onto the new motor.
