Phizinza Posted March 27, 2010 Share Posted March 27, 2010 Ok.. So I'm looking at replacing my with a Liberty (Legacy). I was thinking of possibly getting an auto... I'm usually not into automatics, but I was thinking it might work better at the speeds I race at along with bigger tyres..See I plan to lift it 6 or so inchs, and fit 31's to 33's on it. With a manual I can get a D/R gearbox and run a 4.11 diff, but I'm still thinking at 10 to 40kph racing speeds an auto might work ok and would remove the whole needing to change gears thing! So my questions are, can the 4sp auto hold up to running much larger tyres like this while being hammered around a track like I race on (motocross for 4wd's is how I usually explain it). And also will it work well at 10 to 40kph racing speeds, at rpm's like 4000 to 6000...? Link to comment Share on other sites More sharing options...
Uberoo Posted March 27, 2010 Share Posted March 27, 2010 I always heard that the legacies even with the EJ in there doesn't like to spin 30"+ tires with a single range.but thats just what Ive heard.Ive also heard that a 4EAT is a decent transmission... *both rumors may be heresy and should be treated as such* Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 29, 2010 Share Posted March 29, 2010 Put an auxillary oil-to-air cooler in the tranny cooler lines and they will hold up fine. You can also manually control the duty c soleniod to lock 4wd, or 2wd if you need to slide the front end sideways. It's a good tranny. Some came with pretty low ratios too. Link to comment Share on other sites More sharing options...
Phizinza Posted March 29, 2010 Author Share Posted March 29, 2010 So you think it will work at the slow speeds I want it to while still giving good power to the wheels? Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted March 29, 2010 Share Posted March 29, 2010 It should be fine for power transfer. I just think you should probably change your tranny fluid rather often and do as the above post mentioned. The torque converter should do just fine for allowing enough slip while still pushing enough power. Twitch Link to comment Share on other sites More sharing options...
