bigbearrick Posted March 27, 2010 Share Posted March 27, 2010 (edited) Duh! I meant the transmission filter! So, I bought the X Transmission product and new filter and tranny fluid from the dealer. Jacked up the car and crawled under. COULD NOT see any filter for the trans. '05 OBW. 4 Speed auto with "manual" shift option. Where the heck is the filter???? Is there some kind of cover over it? I mean, heck, it's a spin on; it ought to be visible, right??? Thanks! Edited March 27, 2010 by bigbearrick Link to comment Share on other sites More sharing options...
Gloyale Posted March 27, 2010 Share Posted March 27, 2010 bigbearrick said: Duh! I meant the transmission filter! So, I bought the X Transmission product and new filter and tranny fluid from the dealer. Jacked up the car and crawled under. COULD NOT see any filter for the trans. '05 OBW. 4 Speed auto with "manual" shift option. Where the heck is the filter???? Is there some kind of cover over it? I mean, heck, it's a spin on; it ought to be visible, right??? Thanks! It should be on the drivers side of the trans. Under the area where the Dipstick goes into the trans. However, I have seen a few later model trans that don't have a filter, just a bypass cap where the filter goes. If you can't see a filter, look for a cap about 3 in in diameter, with a 19mm nut in the center of the cap. Side of the trans, just behind the diff, under the dipstick. If you have a cap there.....return the filter. Link to comment Share on other sites More sharing options...
RAYJAY Posted March 28, 2010 Share Posted March 28, 2010 driver side fender well its a remote filter by the fog light you have to pull the inner fender well down (have a 04 gt ) Jeff Link to comment Share on other sites More sharing options...
bigbearrick Posted March 28, 2010 Author Share Posted March 28, 2010 Thanks! I will look harder! Link to comment Share on other sites More sharing options...
