pick n pull in st louis has a good ej22 swap candidate
there is a 1992-94 silver legacy wagon in the pick n pull on hall st in St. Louis in the back row. it was hit in the left doors, center pillar, odometer has 135k miles..
The underhood in still 100% intact. this would be prime for a ej22 swap for someone and the low miles would be a good choice. just fyi for someone, the car was there today.
there is also a 96? outback there with a ej22 engine under the hood, front pulley and sprockets were laying loose as if it had some failure. this had sohc heads.
