KoolKatKodyJack Posted March 30, 2010 Share Posted March 30, 2010 87 gl hatch d/r ea81 i've only driven it twice (had it only a month) but everytime i drive it the oil pressure redlines and i cant figure out why. i wont drive it like that for fear of ruining anything. any guesses? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 30, 2010 Share Posted March 30, 2010 If the wire to the sending unit on the oil pump is broken and grouned anywhere it will peg the gauge out. In any case it's probably a faulty gauge or sending unit. Check the actual pressure with a mechanical gauge - any 0 to 100 psi gauge ought to be sufficient. GD Link to comment Share on other sites More sharing options...
john in KY Posted March 30, 2010 Share Posted March 30, 2010 A chance the previous owner installed the wrong oil pressure sensor. One works with the light and the other with the gauge. They don't interchange. Link to comment Share on other sites More sharing options...
Sonicfrog Posted March 30, 2010 Share Posted March 30, 2010 Check for a short in the wire leading to the sensor in front of the engine. The sensor is right below the crank pulley. Link to comment Share on other sites More sharing options...
KoolKatKodyJack Posted March 30, 2010 Author Share Posted March 30, 2010 thanks ya it looks like it was a short that was an easy fix Link to comment Share on other sites More sharing options...
