987687 Posted March 30, 2010 Share Posted March 30, 2010 So part of the reason I failed inspection is because of a mooshy brake pedal. So I went to bleed them, looks pretty easy. I doused the bleeder screws for about half an hour in PB blaster, one of the rear ones (drum) went nice, the other the bleeder snapped off But whatever, I'll just do a disk swap (bratman is selling me the bits). The bit that really annoys me is that the front left one was really rusty and my socket just rounded the head off. The bleeder screw is still in there though, how should I proceed? Obviously I'll need a new bleeder screw, but how should I get the old one out without damaging anything any worse? I think the situation can be salvaged if I do the right thing. thanks. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 30, 2010 Share Posted March 30, 2010 good quality Vise Grip, maxed to the highest pressure force it will go. Do not use cheapy off brand vise grip, you want the real deal here. Spray some more pb blaster, clamp that sucker on, and hope it will grip to loosen it. Link to comment Share on other sites More sharing options...
987687 Posted March 30, 2010 Author Share Posted March 30, 2010 good quality Vise Grip, maxed to the highest pressure force it will go. Do not use cheapy off brand vise grip, you want the real deal here. Spray some more pb blaster, clamp that sucker on, and hope it will grip to loosen it.I was wicked tempted to use vice grips, but figured I'd hold off until I got some advise. Thanks. I'll go out and see what happens ... I have a very nice pair of grippy vice grips. Wish me luck! Link to comment Share on other sites More sharing options...
ShawnW Posted March 30, 2010 Share Posted March 30, 2010 Snap-On Socket. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 30, 2010 Share Posted March 30, 2010 use the box end wrench on stuff like bleeders, in the future. since the bleeder is hollow you may be able to use an easy out without having to drill. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 30, 2010 Share Posted March 30, 2010 yes, like said above, a closed end wrench will not slip off rounding the corners for future. Link to comment Share on other sites More sharing options...
mcbrat Posted March 30, 2010 Share Posted March 30, 2010 and try not to put too much pressure on the vice grips... I once clamped one shut that was so tight, I pulled a muscle in my neck strainiing to get it shut... but I got it Link to comment Share on other sites More sharing options...
987687 Posted March 30, 2010 Author Share Posted March 30, 2010 Thanks for all the advise. I'll be sure to use a closed end wrench in the future. I didn't have any small enough, so I just used a socket. I'll go buy one. I got it with the vice grips! Kinda squashed the crap out of the bleeder screw, but whatever, it'll come out. Napa is ordering two for me, so I'll just replace both in the front tomorrow when I get the parts. When I pull the bleeder screw all the way out, what's going to happen? ... I'm not going to have a torrent of brake fluid, am I? Link to comment Share on other sites More sharing options...
bheinen74 Posted March 30, 2010 Share Posted March 30, 2010 when you unscrew it, you need to cap it off with a rubber or plastic plug of some sort ASAP. Moisture and brake fluid mixing is not good, need to keep it sealed from the moisture in the air, fluid will dribble out but the cap will stop it.. Link to comment Share on other sites More sharing options...
987687 Posted March 30, 2010 Author Share Posted March 30, 2010 when you unscrew it, you need to cap it off with a rubber or plastic plug of some sort ASAP. Moisture and brake fluid mixing is not good, need to keep it sealed from the moisture in the air, fluid will dribble out but the cap will stop it.. Why cap it? why not just immediately screw the new one back in? Link to comment Share on other sites More sharing options...
bheinen74 Posted March 30, 2010 Share Posted March 30, 2010 it said you were waiting til tomorrow for the napa ordered ones to come in. why of course, put the new one in when you take out the old. Link to comment Share on other sites More sharing options...
987687 Posted March 30, 2010 Author Share Posted March 30, 2010 it said you were waiting til tomorrow for the napa ordered ones to come in. why of course, put the new one in when you take out the old. Cool, I should have mentioned that I didn't actually take the bleeder out, I just got it to turn. So I assumed that since it turned 2 turns it would come all the way out, so I screwed it back in. Link to comment Share on other sites More sharing options...
bratman18 Posted April 2, 2010 Share Posted April 2, 2010 Good luck man!!! Link to comment Share on other sites More sharing options...
