mcbrat Posted October 24, 2011 Share Posted October 24, 2011 monstaru said: Got some more done today.Finally was able to get the bottom gussets to look and fit how I wanted. Only took 5 tries...... Got my free char lynn steering valve to the shop to get checked out.So we'll see whaty goes dowwn there. should be able to cut out the centers to my beadlocks soon.then i can mount the tires. cheers nice touch welding up the steering stops.... Link to comment Share on other sites More sharing options...
monstaru Posted October 24, 2011 Author Share Posted October 24, 2011 McBrat said: nice touch welding up the steering stops.... I actually had to "reshape" them from being bashed quite a bit.I shoved a 5/8 nut down into them to add rigidity, then welded the top and bottom on....cheers Link to comment Share on other sites More sharing options...
monstaru Posted November 16, 2011 Author Share Posted November 16, 2011 So I was able sandblast my H1 rims, get the centers cut out, and order some new centers to get better offset and the Toyota bolt pattern.All I need now is some rock rings.. I had to mock one up:clap: I should be able to get these mounted by the time I leave,hopefully. cheers Link to comment Share on other sites More sharing options...
monstaru Posted November 16, 2011 Author Share Posted November 16, 2011 I have started a new thread, that relegates what is REally happening with this build. http://www.ultimatesubaru.org/forum/showthread.php?p=1058458#post1058458 Link to comment Share on other sites More sharing options...
