metallic scratching from right front axle
Also an intermittent squeal. The noise stops completely after the car stops and doesn't seem related to brake pressure. Brakes are in good shape. Never had this before Friday when I had a right front cv axle installed. Also got an alignment/tire rotation done. I plan on going back tomorrow to hopefully get the issue resolved. Any thoughts? Possible problem with the new axle? The old axle definitely needed replacing. Also, just a little venting about why can't things just be done right the first time. Grumble. '96 outback, 5 spd, 180k miles. Thanks. Did a search but didn't find anything.
Mechanic said the backing plate was rubbing the disc. It was confirmed immediately on the test drive. Now my car just makes the usual noises I'm used to. Hopefully I haven't jinxed everything. Thanks for the input.
Edited by goof_ball
resution
Thanks for the feedback. I was also thinking that with the work going on the area that something could have been inadvertently knocked around. But it is pretty obvious and annoying. Hopefully the short trip back and forth to work will not cause any issues. At least it doesn't make the horrible clunking sound everytime I turn right and step on the gas. Will post the resolution.
