mkoch Posted April 4, 2010 Share Posted April 4, 2010 Like the title says, I wonder if I can remove the drive shaft, rear differential, rear axles, and drive down the road. From what I've observed on the car, there's no reason I shouldn't do this. Is there anything I missed that would make the removal of these parts a problem? Link to comment Share on other sites More sharing options...
NoahDL88 Posted April 4, 2010 Share Posted April 4, 2010 the driveshaft is the plug for the back of the transmission, you'll loose fluid out the back of your transmission Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 5, 2010 Share Posted April 5, 2010 There is no reason to do it - you won't gain any economy. Blocking the fluid from getting out of the transmission is easily solved but it's still pretty much a no gain situation - you lose the 4WD capability but still have the 4WD gearing so the mileage is the same. GD Link to comment Share on other sites More sharing options...
rxleone Posted April 5, 2010 Share Posted April 5, 2010 There is no reason to do it - you won't gain any economy. Blocking the fluid from getting out of the transmission is easily solved but it's still pretty much a no gain situation - you lose the 4WD capability but still have the 4WD gearing so the mileage is the same. GD He's right, the only way you'd really save on economy would be the lost weight, which amounts to bugger all really. Why would you want to do this? Link to comment Share on other sites More sharing options...
mkoch Posted April 5, 2010 Author Share Posted April 5, 2010 He's right, the only way you'd really save on economy would be the lost weight, which amounts to bugger all really. Why would you want to do this? Why I want to do this: I plan to remove the differential, and have it's seals replaced, as well as: new rear axles I don't know how long it will take to get these parts, and I just wanted to drive the car around during the wait. Thanks for the advice. I'll just let the car sit for a couple more weeks. mkoch Link to comment Share on other sites More sharing options...
zyewdall Posted April 5, 2010 Share Posted April 5, 2010 the driveshaft is the plug for the back of the transmission, you'll loose fluid out the back of your transmission Yup... that'll be the problem Link to comment Share on other sites More sharing options...
MilesFox Posted April 5, 2010 Share Posted April 5, 2010 you can pull the rear axles, and leave the diff and driveshaft isntalled. the diff and driveshaft will remain stationary so long as the car is in FWD, and there are no rear axles turning it. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 5, 2010 Share Posted April 5, 2010 the rear axles are what hold the hubs/ rotors on...... you still need stubs in there, unless you dont mind rear wheels falling off... Link to comment Share on other sites More sharing options...
baccaruda Posted April 5, 2010 Share Posted April 5, 2010 uh, the rear axles don't hold the wheels on like in the front. As long as he pulls the axles but leaves their stubs in the hubs he's fine. As long as you can keep from losing fluid, you can yank the rear axles, the diff, and the driveline. One trick I've used before was to stick a shifter knob inside of an axle boot, and push the threaded end of the knob through the small aperture of the boot, and clamp it.. then stick the boot over the transmission output in place of the yoke and clamp it on; the gear oil should all stay where it is. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 5, 2010 Share Posted April 5, 2010 wow i am wrong i forgot how long it been since i removed a brat axle. party on. Link to comment Share on other sites More sharing options...
