Justy Exhaust Sources
I need the mid-pipe that has the flex joint. All aftermarket pipes omit the flex joint. I have an email into 1st subaru to see if this even exists anymore (it is listed on the website but a bit pricey)
nipper
reading the review of the above
""had to return item because it was too long for my use. item has very little sideways flexibility for installation but would be good once installed for absorbing vibrations." "
take into account this may be rigid almost like a regular solid pipe.
The one in the Justy is farily, er um, rigid. They are tuned not to transmit engine vibartion and movement. Yhere is a lot more forces from the engine then from your hands. This may also solve a problem I have had with Blus exhaust system since the lift.
nipper
Been talking to DustysJusties. Heis considered to be the Guru of Justies. He said one can use a straight pipe. Thanks all.
When it gets on the road i will go to amuffler shop and see if they can do it cheaper then the part costs.
