garbage Posted April 8, 2010 Share Posted April 8, 2010 does a ej22t come stock with forged or dished pistons? Link to comment Share on other sites More sharing options...
subaru360 Posted April 8, 2010 Share Posted April 8, 2010 cast pistons 7.5:1 or so compression Link to comment Share on other sites More sharing options...
bheinen74 Posted April 8, 2010 Share Posted April 8, 2010 forged crank rod and pistons, capable of 30psi boost levels all day on the stock setup.......with engine management and bigger turbo, high flow injectors. Best engine Subaru ever made..1991 was the only year with the oil filter cooler machined into the block, 92-94 did not have that. All had piston oil squirters to help cool.... http://www.angelfire.com/md3/91turbolegacy/background.html Link to comment Share on other sites More sharing options...
subaru360 Posted April 8, 2010 Share Posted April 8, 2010 No, EJ22t rods and cranks are the same as EJ22e, EJ18 etc and the pistons are cast. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 8, 2010 Share Posted April 8, 2010 disagree... ej22t The stock con rods, although forged, are thinner than your typical aftermarket forged rods, however, like the pistons, these rods have been known to withstand up to 350 crank hp. The EJ22T’s crankshaft is forged and heat treated steel and weighs only 20 lbs. Total length is only 13.5 inches. The short stroke design gives about .750 inch of crank pin vs. main journal overlap, making it very stiff. Oiling is reasonably well thought out. The crank fillets are rolled for low stress and fatigue resistance. Journal diameters are 2.36 mains and 2.05 on the rods. The crank is fully counterweighted, contributing to the overall smoothness of engine operation. Link to comment Share on other sites More sharing options...
subaru360 Posted April 8, 2010 Share Posted April 8, 2010 So some idiot made a website with bad info. I've had these engines apart side by side and they are the same. Same part numbers too. Go to the dealer and check if you doubt me. EJ22E and EJ22T take the same part number crank and rods. Link to comment Share on other sites More sharing options...
Turbone Posted April 8, 2010 Share Posted April 8, 2010 Might be a good idea to read thru this thread, but heres a post pertaining to this discussion. And Matt Monson knows what he's talking about... Actually they are sought solely for the closed deck block. The crank and rods are nothing special and not really different from any other Subaru engine. And if you switch in the pistons, which are cast, not forged and also nothing special, and mate the Ej25 heads onto it, you get super low compression down around 7:1. It's better to just leave the Ej22E pistons in place because it keeps the comprssion in the mid 8's:1 and you don't have to crack the case. http://bbs.legacycentral.org/viewtopic.php?f=5&t=36656 Link to comment Share on other sites More sharing options...
Legacy777 Posted April 8, 2010 Share Posted April 8, 2010 I've got mine apart right now. As mentioned, the crank and rods are forged, but are the same as what is in the non-turbo engines. I will be putting Eagle rods back in with forged Weiseco pistons. Compression ratio with the stock pistons is 8.0:1 Here are some miscellaneous pictures of the tear down. http://main.experiencetherave.com/subaru/images/ej22t_headwork/ Link to comment Share on other sites More sharing options...
wtdash Posted April 10, 2010 Share Posted April 10, 2010 Pistons are cast but coated in the EJ22T...check this LINK for more info, but essentially: "........and the pistons were given a dished crown (which lowers the compression ratio from 9.5:1 to 8.0:1), stronger rings, longer wrist pins and a molybdenum coating." Link to comment Share on other sites More sharing options...
subaru360 Posted April 10, 2010 Share Posted April 10, 2010 Pistons are cast but coated in the EJ22T...check this LINK for more info, but essentially: "........and the pistons were given a dished crown (which lowers the compression ratio from 9.5:1 to 8.0:1), stronger rings, longer wrist pins and a molybdenum coating." Again, anyone can make a website or a post on one. How could the wrist pin be longer? They would hang out the side of the piston. Link to comment Share on other sites More sharing options...
Legacy777 Posted April 11, 2010 Share Posted April 11, 2010 Again, anyone can make a website or a post on one. How could the wrist pin be longer? They would hang out the side of the piston. The wrist pins have a different part # in the subaru parts catalog. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 12, 2010 Share Posted April 12, 2010 pretty sure all these questions and answers are posted over on bbs.legacycentral.org no use in beating it over and over again, when a search there will provide all info. Link to comment Share on other sites More sharing options...
