scoobyclimbs Posted April 9, 2010 Share Posted April 9, 2010 What is the ft. lbs of pressure the xt-6 pressure plate holds? I what to compare to a 99 legacy/impreza specs. Link to comment Share on other sites More sharing options...
ruparts Posted April 10, 2010 Share Posted April 10, 2010 scoobyclimbs said: What is the ft. lbs of pressure the xt-6 pressure plate holds?I what to compare to a 99 legacy/impreza specs. hi, according to the 88 manual PP= 500kg/1103lb, surface 228 od, 147 id. the disc= od 225, id 150, thick 3.5(0.138in) 25 spline x 25.2 dia.(0.992in). for reference the 1.8 4x4 clutch has 350kg/772lb/ the turbo xt clutch had 400kg/882lb, same size specs on the disc, for both, but the springs in the disc are set up in a different configuration on the xt6 disc, than the 1.8 4x4 & turbo-4 disc. Link to comment Share on other sites More sharing options...
