scoobyclimbs Posted April 9, 2010 Share Posted April 9, 2010 What is the ft. lbs of pressure the xt-6 pressure plate holds? I what to compare to a 99 legacy/impreza specs. Link to comment Share on other sites More sharing options...
ruparts Posted April 10, 2010 Share Posted April 10, 2010 What is the ft. lbs of pressure the xt-6 pressure plate holds?I what to compare to a 99 legacy/impreza specs. hi, according to the 88 manual PP= 500kg/1103lb, surface 228 od, 147 id. the disc= od 225, id 150, thick 3.5(0.138in) 25 spline x 25.2 dia.(0.992in). for reference the 1.8 4x4 clutch has 350kg/772lb/ the turbo xt clutch had 400kg/882lb, same size specs on the disc, for both, but the springs in the disc are set up in a different configuration on the xt6 disc, than the 1.8 4x4 & turbo-4 disc. Link to comment Share on other sites More sharing options...
