Announcements
HiPo EA81 build questions....domed pistons?
I have been thinking of doing this for some time now and i think its getting closer to the time when i will actually dive in. I do have a a few questions though. I had a rough game plan worked out that involved:
-Heads done by Jerry Demoss
-delta cam (probably hp grind but not sure just yet)
-SPFI pistons
-Single weber tuned....for now
-and possibly new everything like bearings and such-mind u this is going into a EA81 with barely 53k miles on it.
Here is the wrench thrown in the mix though from that formula. I have the opportunity to purchase some domed pistons for an EA81 made by an aftermarket company that no longer exists. I dont know what it would do to the compression ratio or the valve clearance because i have seen how high up on the block the SPFI pistons go and there is virtually no clearance with those if i were to deck the heads .030. Here is a picture of the pistons he sent me. Or would it be a matter of...if i were to use these pistons i dont deck the heads at all?
Thoughts? Im just worried that it will be too much and i wont be able to run it on pump gas or that the pistons will be the wrong sizes ( i know that there is an A and a B size piston). Let me know.
Edited by hatchsub
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
SPFI pistons would give you 9.5:1....... much higher than that and you'll be running premium if not avgas.
Those things look like they might put it up to 11:1 or higher..... I don't think that's what you want since you can't easily get 120 octane fuel...... I mean - they have a cut-out for the plug electrode..... good god man!
Looks like something you would see for a deisel conversion :rolleyes:
Edited by GeneralDisorder
First, the pistons and head cc's make up the compression. So, SPFI will not guarrantee 9.5/1.
The best combination I came up with was;
Hydraulic heads(large valve) - blended ports
1600 pistons
Decked .020 - any more and you'll have problems installing the intake
Port matched intake adapter for the Weber
Weber 32/36 with the biggest jets I could find
lightened EA82 flywheel
XT6 clutch assy.
Cam of your choice. I built two of these motors for myself and a couple of them for board members. McBrat has one and so does Edrach. There really is no comparison. Turbone is driving one of them and Breeke is driving the other one. Breekes replaced an EA82 with the one with the torque cam. Turbone is driving my old BRAT with the HP cam. That BRAT constantly set fast times at local rallycross events. It has a few other goodies as well though. I could run down a friends slightly modded turbo wagon with out a problem. He was just slightly disappointed when that happened.
The only combination that would be better than these would be a set of RAM heads. But, those cost more than a lot of the vehicles here.
Did those pistons come from NSI in Arlington, Washington? You do not have to worry about "zero" clearance on a gear-driven motor. The biggest thing would be the fuel availibilty for such pistons and the compression they would generate.. Since they were designed for gyro and ultra-lights they usually had access to av-gas, do you?
Edited by Qman
1600 pistons
XT6 clutch assy.
Did those pistons come from NSI in Arlington, Washington? You do not have to worry about "zero" clearance on a gear-driven motor. The biggest thing would be the fuel availibilty for such pistons and the compression they would generate.. Since they were designed for gyro and ultra-lights the usually had access to av-gas, do you?
Yeah, I remember that lol
Ok everyone answered that question. Those are out. Thanks guys. Game plan back on track :banana:
New question....will a stock 2wd clutch with about 30k miles on it now hold up to the 100 or so hp that i think my motor will make when done?
Btw those are on ebay if anyone else wants a go at em
If driven conservatively, yes. Otherwise, no!
I would look at using, at the very least, an EA82 clutch and flywheel. Anything less and you run the risk of slippage. An XT6 assy would be slightly over-kill but would not slip under load.
Edited by Qman
I beleive that is also possible if you use the right T/O bearing - I think some older threads have discussed using a T/O for either a Nissan or Isuzu truck of some kind. I've never tried it personally but that is the biggest obstical to using the 5 speed/XT6 pressure plate with the 2WD or 4 speed transmissions.
Also - if you have the flywheel cut right - you shouldn't have any slippage problems with the 4 speed 225mm clutch. On my wagon I can easily chirp the 28" tires with a stock EA81/4 speed. I don't think slippage would be a problem if the clutch is new and the flywheel is cut properly. At least that's been my experience. The 200mm clutch would slip like mad just taking off from a light with the 28's - once I put in the 4WD clutch though it became a non-issue.
No, you use the throwout bearing for the transmission you are using.
Well - I wouldn't be comfortable with the stock 2WD/4 Speed T/O as it doesn't contact the 5 speed/XT6 pressure plate fingers correctly at all. It barely touches them at the outer edge of the T/O. It might work for a time - but with a little wear to the pressure plate fingers it would go right through them.
They touch just fine. The only reason to use the that TO bearing is that it matches the fork. But, if you are comfortable with it you can use a 4wd TO. Mounts up the same. And, if you are really worried about it you can use a 4wd wagon bearing... :rolleyes:
From what I understand - the Nissan truck T/O mounts up the same - IE: it will mount to the T/O "holder" for the EA transmission. It's just larger in diameter so provides a more correct PP finger contact.
What is the difference between a 4WD and a 4WD wagon T/O? I'm assuming you mean for 4 speed's..... I haven't seen a difference between any of the 4 speed 4WD T/O's.....
Rick, from what you understand? You haven't done one of these?
I have done several. It will be fine. It will hold the power better than a stock clutch. The build will need better holding power. The clutch I recommended will do the job as stated.
Subaru calls for two different TO's for 4wd's. Wagons and non-wagons. I would guess for the difference in weight. Otherwise, who knows, it could be superseded by now any way.
No. But I have mocked up the parts and also have had a T/O bearing lock up and wear through the PP fingers even with proper contact.... and I've seen plenty of PP's with wear on the T/O contact surfaces. I'm not saying it won't work - just that I would be concerned about it's longevity with ~1/8" of the OD of the T/O touching the fingers. Seems like it wouldn't last is all I'm saying. I'm sure it would *work* - just not comfortable with what I see looking at how the parts mate up. And if there's a larger diameter T/O availible that will correct this issue - why not investigate the possibility? What's wrong with at least taking the time to check it out?
I agree the holding power of the XT6 setup is a good call. Just want to make sure it's going to give years of service for him.
Maybe that is the key - I'll see if my dealer can answer as to the physical difference if the part numbers are still different. They are pretty cool about such things.
Ok - some numbers:
EA82 4WD 5 speed T/O bearing:
OD: 3.15" (but the PP contact "bump" is slightly inboard of the OD due to the stamped steel design)
EA81 4WD 4 speed T/O bearing:
OD: 2.5039"
(Bore: 1.5748" - to mount to T/O bearing holder)
1990 Nissan D21 Pickup (2.4L 4 cylinder) T/O bearing:
OD: 2.8898" (PP contact "bump" is right on the OD)
(Bore: 1.5748" - same style mount as EA81 - on cast bearing holder)
If it's me - I'm useing the XT6 kit like Ken sugests - but with the Nissan T/O. For the extra $25 it's just peice of mind. But.... it's a judgement call I suppose.
And along those lines, since it seems ea71 pistons will fit ea81 block then will an ea81 crank work in a ea71 block. Heads interchange?
I didn't find any thing in search that gave much specifics if any info...:-\
Crank and heads - no they won't interchange. Pistons will interchange across all the 92mm bore engines - EA71/EA81/EA82.
The EA71 pistons are taller from the wrist pin to the top of the piston - by around .010" IIRC. It bumps the compression up from 8.7 to around 9.5
ok I have to ask, what if the EA71 pistons went in an EA82? (which started at 9.5:1?)
