biffanyus Posted April 12, 2010 Share Posted April 12, 2010 I have a 79 brat with the dual headlight set up(one on each side). They only work on high beams but not low. Any suggestions??? Quote Link to comment Share on other sites More sharing options...
Don_Quixpunch Posted April 12, 2010 Share Posted April 12, 2010 First off, I'd pull the plugs on the bulbs and make sure they have three prongs. If they do, your best option is to use a test light and make sure there's power to low beam prong, if so, you need new bulbs. Failing that, it's a matter of working your way through the wiring back to the switch until you find the broken wire or connection. Good luck. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted April 12, 2010 Share Posted April 12, 2010 Could be the stalk on the steering wheel. The contacts are in that assembly. Somtimes they need cleaned, sanded and repositioned. Quote Link to comment Share on other sites More sharing options...
Leeroy Posted April 13, 2010 Share Posted April 13, 2010 Could be the stalk on the steering wheel. The contacts are in that assembly. Somtimes they need cleaned, sanded and repositioned. My thoughts exactly! The other thing to check is the glass fuses. I have had no end of trouble with lights going off over bumps and what not until I started buying better quality fuses from electronics stores. Most places in Australia now only stock cheap, made in China fuses which are basically useless. Quote Link to comment Share on other sites More sharing options...
Don_Quixpunch Posted April 16, 2010 Share Posted April 16, 2010 Hey Biff. I'm curious if you got any resolution with your headlight problem. Quote Link to comment Share on other sites More sharing options...
biffanyus Posted April 19, 2010 Author Share Posted April 19, 2010 Hey Biff. I'm curious if you got any resolution with your headlight problem. Thanks for the advice... Well Don... I havent tackled that yet, I have to many other issues first. Lack of power... Windsheild leaking... Clutch.... No plate lights(some rump roast clown cut the wires that lead to them)... ETC ETC... I will post as soon as I get to that. Quote Link to comment Share on other sites More sharing options...
Don_Quixpunch Posted April 19, 2010 Share Posted April 19, 2010 Sounds like you've got a winner on your hands. I won't even go into the laundry list of problems my Brat has. For some reason many of these old Soobies seem to have gone through assclown ownership before we get them. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted April 19, 2010 Share Posted April 19, 2010 plus, the wiring in the old soobs is suspect anyway from age... Quote Link to comment Share on other sites More sharing options...
