Funny Headlight situation Help Please
First off, I'd pull the plugs on the bulbs and make sure they have three prongs. If they do, your best option is to use a test light and make sure there's power to low beam prong, if so, you need new bulbs. Failing that, it's a matter of working your way through the wiring back to the switch until you find the broken wire or connection.
Good luck.
  SUBARU3 said:
Could be the stalk on the steering wheel. The contacts are in that assembly. Somtimes they need cleaned, sanded and repositioned.
My thoughts exactly!
The other thing to check is the glass fuses. I have had no end of trouble with lights going off over bumps and what not until I started buying better quality fuses from electronics stores. Most places in Australia now only stock cheap, made in China fuses which are basically useless.
  Don_Quixpunch said:
Hey Biff. I'm curious if you got any resolution with your headlight problem.
Thanks for the advice...
Well Don... I havent tackled that yet, I have to many other issues first. Lack of power... Windsheild leaking... Clutch.... No plate lights(some rump roast clown cut the wires that lead to them)... ETC ETC... I will post as soon as I get to that.
