TheLoyale Posted February 1, 2012 Author Share Posted February 1, 2012 DIY EJ Strut Lift Blocks: Thanks to Monstru. http://www.ultimatesubaru.org/forum/showthread.php?t=128665&page=4 Link to comment Share on other sites More sharing options...
TheLoyale Posted February 1, 2012 Author Share Posted February 1, 2012 Link to comment Share on other sites More sharing options...
jboymechanic Posted February 2, 2012 Share Posted February 2, 2012 Have room for any more stickers? Link to comment Share on other sites More sharing options...
subynut Posted February 2, 2012 Share Posted February 2, 2012 jboymechanic said: Have room for any more stickers? Oh, there's plenty of space! Link to comment Share on other sites More sharing options...
TheLoyale Posted February 2, 2012 Author Share Posted February 2, 2012 jboymechanic said: Have room for any more stickers? Its pure class. Don't you forget it! Link to comment Share on other sites More sharing options...
TheLoyale Posted February 2, 2012 Author Share Posted February 2, 2012 Jon, Just thought about this, your Dodge is gonna get some bad milage with the plow on it! Its like 20 miles round trip from your place to mine and my place to yours. (Does that make sense?) lol Have you been out to Al's at all in the past week/end? I hope Norm is a man of his word and that '96 is still there, I am hoping to snag it for no more then $325 ... Link to comment Share on other sites More sharing options...
jboymechanic Posted February 2, 2012 Share Posted February 2, 2012 The Dodge gets 14 mpg no matter what, not worried about the plow. Make sure you let me know how tomorrow goes picking up the trans. Hopefully this warm weather will keep up through the weekend. Either way, I'll be ready. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 2, 2012 Author Share Posted February 2, 2012 I hear that! The weather we had Tuesday was the cats rump roast. I'll give you a text tomorrow and let you know whats up. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 2, 2012 Author Share Posted February 2, 2012 I also need to grab some new Fuel line to replace the Trans cooling lines with. Anyone know off hand what size it is? 3/8"? Link to comment Share on other sites More sharing options...
TheLoyale Posted February 3, 2012 Author Share Posted February 3, 2012 $350 4EAT 4:11 173,000. Trans code. Link to comment Share on other sites More sharing options...
987687 Posted February 3, 2012 Share Posted February 3, 2012 I see that someone cut the axles off instead of pulling them off the proper way... I bought one of those. $150 for a 5speed with driveshaft and rear end.. Not only did they cut the axles off, they got a punch stuck inside of the roll pin and broke the punch off. On both sides. It took me an hour with an angle grinder and my BFH + subaru axle pin tool to get the stuck pins out. Then the axles were stuck to the stub shafts.... so more BFH fun.... Just don't give the diff bearings too much love... Hope those axles come off nicely for you. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 3, 2012 Author Share Posted February 3, 2012 Yeah, a Junkyard isn't going to waste time removing the axles when they have a Torch. Hell, they even cut the exhaust and trans crossmember off (So I have to replace the Tranny mounts with my original ones) they also cut the shifter cable and burn the o2 sensor wiring (Which I can all swap from mine) no biggie. The axles came out easy, someone replace the axle once on that car (Aftermarket DOJ and roll pin) and I think someone was messing with the diff stub bearings/seal or something, as the retainer clip was loose. So I just checked the it out and tightened it up. My end play is good, and there is no other play in the stubs, so I think we're in good shape so far. Link to comment Share on other sites More sharing options...
987687 Posted February 3, 2012 Share Posted February 3, 2012 TheLoyale said: Yeah, a Junkyard isn't going to waste time removing the axles when they have a Torch. Hell, they even cut the exhaust and trans crossmember off (So I have to replace the Tranny mounts with my original ones) they also cut the shifter cable and burn the o2 sensor wiring (Which I can all swap from mine) no biggie. The axles came out easy, someone replace the axle once on that car (Aftermarket DOJ and roll pin) and I think someone was messing with the diff stub bearings/seal or something, as the retainer clip was loose. So I just checked the it out and tightened it up. My end play is good, and there is no other play in the stubs, so I think we're in good shape so far. Wait a min, the weird gear-looking ring on the transmission that goes around the stub was loose?! There's supposed to be a lock nut and tab to keep those from turning. They set the diff backlash. If they've been messed with, the backlash is wrong and the diff won't last long. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 4, 2012 Author Share Posted February 4, 2012 987687 said: Wait a min, the weird gear-looking ring on the transmission that goes around the stub was loose?! There's supposed to be a lock nut and tab to keep those from turning. They set the diff backlash. If they've been messed with, the backlash is wrong and the diff won't last long. The Gear-looking ring thing was tight, but the little retainer (Locknut thing) was loose. So it makes me wonder. But it feels ok, smooth and easy, and has the same amount of lash on each shaft. Guess we'll see. (Hence the reason of buying an FJ60) the gear box can be someone elses problem Link to comment Share on other sites More sharing options...
jboymechanic Posted February 6, 2012 Share Posted February 6, 2012 What, no update Tom? I guess I'll spoil it for you, Safariwagon II lives on! Link to comment Share on other sites More sharing options...
TheLoyale Posted February 6, 2012 Author Share Posted February 6, 2012 (edited) jboymechanic said: What, no update Tom? I guess I'll spoil it for you, Safariwagon II lives on! For the moment, The transmission shifts fine, and enter TC lockup. But in Reverse, I have some serious vibration (This is not a trans mount issue) I also have a tapping in drive while stopped off and on. Also while cornering it feels like something is grabbing the outer most wheel and slowing it down, wonder if the Diff just needs to be worked in? This might have been a waste of $400 and our labor. I am going to adjust the shifter cable today, and look at this thing more. My tranny pan also leaks, after I resealed it (So I am going to use my Original one) as the flange on this one was bent. Edited February 6, 2012 by TheLoyale Link to comment Share on other sites More sharing options...
MilesFox Posted February 6, 2012 Share Posted February 6, 2012 maybe that diff ring had been screwed with. Good luck with the car. I will drop a hint that the guy who bought my engine might be interested in the xt for a premium, and if this comes true, i would make an offer on your car that reflects the asking price. I need something that is appropriate to haul my child around if i have to do errands while the woman is at work. the rusty GL with a broken window is not wise. This is just an idea at this time. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 6, 2012 Author Share Posted February 6, 2012 $1,100 takes this car, I'm already an extra $400 into this thing with the trans swap, car comes with everything, as is. I am really done with this car, I am just to that point (You've been there) The trans swap did not yield the results I had hoped for. Link to comment Share on other sites More sharing options...
MilesFox Posted February 6, 2012 Share Posted February 6, 2012 sorry to hear that. I'll put the word locally that its for sale for that price. I may have my brown wagon sold soon, among other things. Link to comment Share on other sites More sharing options...
jboymechanic Posted February 7, 2012 Share Posted February 7, 2012 TheLoyale said: $1,100 takes this car, I'm already an extra $400 into this thing with the trans swap, car comes with everything, as is. I am really done with this car, I am just to that point (You've been there) The trans swap did not yield the results I had hoped for. :-\ Bummer, but I'd buy the tires and wheels. Or trade for you BFGoodrichs on steelies back or something inbetween. Link to comment Share on other sites More sharing options...
987687 Posted February 7, 2012 Share Posted February 7, 2012 Sucks I'd take it for that price, too bad it's too far away. I want a wagon pretty bad. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 7, 2012 Author Share Posted February 7, 2012 These are $900 Potenza G019s. A trade would not be worth it, and it is even more pointless since I would have no use for those BFGs. jboymechanic said: :-\ Bummer, but I'd buy the tires and wheels. Or trade for you BFGoodrichs on steelies back or something inbetween. Keep in mind, if I get this thing acting the way it should, no noises, shift lever lines up with correct gear etc. The price of this rig goes up to $2,000, and will be listed on CL as such. Link to comment Share on other sites More sharing options...
Red92 Posted February 7, 2012 Share Posted February 7, 2012 TheLoyale said: These are $900 Potenza G019s. A trade would not be worth it, and it is even more pointless since I would have no use for those BFGs. His offer actually could help you out substantially, if you think about it. If you have a car with $900 of nearly new tires, and you're going to sell the car as a whole for $1100, then you're basically selling the car portion (not counting the tires) for less than scrap price. When you consider that alloy wheels are $50/each at the scrap yard, and not terribly much less when sold private party, then the car itself is basically free for whoever buys the wheels and tires! Here's the benefit: A swap+cash for some lesser wheels/tires would help you recover your investment in the tires, and then let you still sell the car as a rolling drivable car. YOU yourself don't need the BFGs - the future owner of your Legacy does. It might be an easy way to get more $$ overall, with a very low level of effort. That is, of course, assuming you don't get it fixed first. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 7, 2012 Author Share Posted February 7, 2012 That is true, but I'm looking at it as, everything works together on this car, its stance + wheel/tire combo + paint scheme + Decals + Interior + Lights. It all works together, with every detail, if I throw on some black steelies with some 27" BFGs, it won't look that same and would probably make it less appealing to buyer(s) Incase you haven't noticed, I am a very detail oriented person lol... Link to comment Share on other sites More sharing options...
TheLoyale Posted February 7, 2012 Author Share Posted February 7, 2012 Plastic Oil Plate (Resealed) Rear main is clean and no leaks Link to comment Share on other sites More sharing options...
