Txakura Posted April 12, 2010 Share Posted April 12, 2010 Ok, so I have prowled around a bit but haven't seen anything concrete on a 'JDM ea82T'. Assuming this unicorn exists, what, if any, differences are there between it and it's US counterpart? And how would you tell them apart? Link to comment Share on other sites More sharing options...
GLCraig Posted April 12, 2010 Share Posted April 12, 2010 They did exist at one time but finding one from an importer will be a challenge. Link to comment Share on other sites More sharing options...
T'subaru Posted April 12, 2010 Share Posted April 12, 2010 I have a couple that have a tube threaded into the underside of the head near the exh pipe that have been cut and crimped. Link to comment Share on other sites More sharing options...
Turbone Posted April 12, 2010 Share Posted April 12, 2010 Every crate engine you buy is JDM. Dont think I've ever heard of a "mythological JDM EA82T" before. Link to comment Share on other sites More sharing options...
88 EA82T Posted April 12, 2010 Share Posted April 12, 2010 The JDM EA82T in my car came from: Foreign Engines Inc 417 Northwest Blvd, Coeur d Alene, ID 83814 (208) 664-1559 You could call them and ask. I don't have any idea what the differences are since I don't have a point of reference. The motor was installed while my brother owed the car about ten years ago. The only thing I have seen is another 02 sensor that is right at the exhaust exit of the turbo but the wires are cut right there. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 12, 2010 Share Posted April 12, 2010 sensors, smog control sensors and devices, intake Link to comment Share on other sites More sharing options...
ruparts Posted April 12, 2010 Share Posted April 12, 2010 Ok, so I have prowled around a bit but haven't seen anything concrete on a 'JDM ea82T'. Assuming this unicorn exists, what, if any, differences are there between it and it's US counterpart? And how would you tell them apart? I bought one in dallas 2 yrs back,( its still doing pretty good), it had no egr port in the head, the boss was there but not drilled through. also had a 2 pin white plastic knock sensor, US is usually green 1 pin, except 85-86. mine was from an xt cause the harness exited in the center rear and had the flat belt grooved pulleys. also the bell housing part was different and would not fit, and the timing hole was in a slightly different location. thats some of the differences. Link to comment Share on other sites More sharing options...
idosubaru Posted April 12, 2010 Share Posted April 12, 2010 any importer of JDM engines can get you one if they're available. have you called and asked about availability? you would bolt up your intake manifold to the JDM block. a picture of one: http://subaru.kacsh.com/rx4.html Link to comment Share on other sites More sharing options...
rxleone Posted April 12, 2010 Share Posted April 12, 2010 Mythological? (Almost) Every single EA82T in NZ is a Japanese Import, so I take it thats what you mean by JDM? JDM is also my initials. Awesome. Link to comment Share on other sites More sharing options...
Turbone Posted April 13, 2010 Share Posted April 13, 2010 When we say JDM here, it means that the engine was originally in a Japanese car and was pulled after ~60K. Then its shipped out to where ever. Link to comment Share on other sites More sharing options...
Txakura Posted April 13, 2010 Author Share Posted April 13, 2010 Every crate engine you buy is JDM.Dont think I've ever heard of a "mythological JDM EA82T" before. it's right next to the 'hypothetical EJ 22', and if I had titled this anything else I doubt I'd have gotten so many answers so fast but seriously, great input from all are their any internal differences? cam, heads... yadda yadda? Link to comment Share on other sites More sharing options...
Turbone Posted April 13, 2010 Share Posted April 13, 2010 The engines that were EDM had better intakes(heads too?) on them and gained a few more horses. I believe these were exclusively on the turbo XT's. Link to comment Share on other sites More sharing options...
nncoolg Posted April 14, 2010 Share Posted April 14, 2010 ...I don't know why it would have a different bell housing, please ellaborate... Link to comment Share on other sites More sharing options...
Major Lazy Posted April 14, 2010 Share Posted April 14, 2010 http://foreignengines.com/ You can buy one here. I did and all you need to do is swap the intake because the harness comes off the passengers side not the drivers side. Link to comment Share on other sites More sharing options...
