97ej22 Posted April 15, 2010 Share Posted April 15, 2010 of something not working...:banghead:on my way home the gear box basicly froze (5spd) it wouldnt let me in 2nd and when i tryed to get out it wouldnt let me eather...so i talked to my friend and he said syncros...any ideas on how much that works gonna be or if its some thing else? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 15, 2010 Share Posted April 15, 2010 Check the linkage for the shifter first. If there is any slop in the bushings it can bind and give the impression of being stuck in gear. Also check the fluid level and the condition of the fluid. A more common reason for a manual transmission to stick in or out of gear is the clutch is failing to fully disengage. This could mean there is air in the hydraulic lines or the cable is out of adjustment depending on which type of actuation system the car has. Another common problem on Subarus is for the release fork to crack near the pivot. This causes the fork to flex more than normal and can prevent the clutch from disengaging. Unfortunately, this one requires removal of the transmission to repair. Quote Link to comment Share on other sites More sharing options...
97ej22 Posted April 15, 2010 Author Share Posted April 15, 2010 they all sound posible...eather way im bringing the car to a tranny shop and letting them do it...trannys are like a dark cave to me Quote Link to comment Share on other sites More sharing options...
987687 Posted April 16, 2010 Share Posted April 16, 2010 Tell us what the verdict, I'm interested to hear. Quote Link to comment Share on other sites More sharing options...
97ej22 Posted April 16, 2010 Author Share Posted April 16, 2010 well 2day when i went to drive it it acted like nothing happend :banghead: but it like to squeak at low speeds or inbetween gears if i drive it hard but i didnt bring it any where to be checked out Quote Link to comment Share on other sites More sharing options...
2.5_IMP Posted April 16, 2010 Share Posted April 16, 2010 well 2day when i went to drive it it acted like nothing happend :banghead: but it like to squeak at low speeds or inbetween gears if i drive it hard but i didnt bring it any where to be checked out You just answered your own question. Quote Link to comment Share on other sites More sharing options...
97ej22 Posted April 16, 2010 Author Share Posted April 16, 2010 yea but it never did that b4 Quote Link to comment Share on other sites More sharing options...
eulogious Posted April 16, 2010 Share Posted April 16, 2010 I think he's trying to tell you why it's bad now. Of course it was fine/didn't do that before until it broke The reason why it probably broke was because you drove it hard. Drive older cars hard, and things tend to break... Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted April 16, 2010 Share Posted April 16, 2010 People fail to understand why you cannot launch, smoke show tires on a AWD car. There is more grip at all 4 wheels on the AWD car. Friends with FWD or rear wheel drive cars can sit and spin tires, because only 2 tires are putting down traction. On a AWD car, there is less ability to lose traction, tires will not spin, instead, transmission is like GLASS. The break when they are abused. done I have been following your threads, First you wanted to make it fast. I warned to search on NASIOC about fragile like glass transmission, but a mod on here pulled my Thread on that. Not sure why they pulled my thread, as that advice was what you need. Quote Link to comment Share on other sites More sharing options...
97ej22 Posted April 16, 2010 Author Share Posted April 16, 2010 yea i understand that and i dont launch it all the time...maybe like once or twice a month Quote Link to comment Share on other sites More sharing options...
Qman Posted April 16, 2010 Share Posted April 16, 2010 yea i understand that and i dont launch it all the time...maybe like once or twice a month You can not hard shift these transmissions. The syncros are weak. It acted like nothing happened because it cooled back down. It will only do this a few times before it grenades. Quote Link to comment Share on other sites More sharing options...
97ej22 Posted April 17, 2010 Author Share Posted April 17, 2010 i put tranny fluid in and it feels a little better but it poped me outta 1st and 2nd dosent like to engage Quote Link to comment Share on other sites More sharing options...
RallyKeith Posted April 20, 2010 Share Posted April 20, 2010 You have learned the hard way what NOT to do to your transmission. I once owned a 97 5psd Impreza. I did a panic super hard shift from 1st to 2nd while trying to avoid being rear ended at a stop sign. I avoided the rear ending but I couldn't get the car out of 2nd for the drive home. The next day I got it out of 2nd but it wouldn't go back in. 1,3,4,5 and R all worked fine. My car was almost brand new at the time. Took it back to the dealer. They pulled apart the transmission and found the 1-2 shift fork was bent. The bottom line is the cars do have limits and in almost any subaru the tranny is the weakest link because of the AWD and massive amount of force that gets generated by the traction of all 4 wheels. In your era of car the transmissions have a real issue with the syncros and shifting with 1st and 2nd gear. I'm sure by now you've noticed you have to be at almost a complete stop to get the car into 1st. Don't force it or you can cause the same damage. They've gotten much better as the years progressed. My '06 shifts like a dream when compared to my 95-97 era cars. Good luck on getting it fixed. Keith Quote Link to comment Share on other sites More sharing options...
97ej22 Posted April 21, 2010 Author Share Posted April 21, 2010 yea i tend to be stupid when it comes to pushing limits since this is my 3rd car and 2nd tranny problem... and how much did it cost for the fork problem to be fixed assumeing u went to subaru to get it done Quote Link to comment Share on other sites More sharing options...
