amk Posted April 15, 2010 Share Posted April 15, 2010 Hi, I own a Subaru Leone with a Wrx EJ20G Motor in it, Competition gear box, Z4 Ecu with a stage 3 chip in it, Rear Wheel Drive. I need help in wiring a Data Link Connector, OBD I or OBD II, I have no idea which wire goes where to the ECU. Can I get some help with this please? Thanks, Regards, Amk. Link to comment Share on other sites More sharing options...
NoahDL88 Posted April 15, 2010 Share Posted April 15, 2010 Hi, I own a Subaru Leone with a Wrx EJ20G Motor in it, Competition gear box, Z4 Ecu with a stage 3 chip in it, Rear Wheel Drive. I need help in wiring a Data Link Connector, OBD I or OBD II, I have no idea which wire goes where to the ECU. Can I get some help with this please? Thanks, Regards, Amk. Now we can read it What year is your engine? that will determine if its obd 1 or obd 2 Link to comment Share on other sites More sharing options...
rxleone Posted April 15, 2010 Share Posted April 15, 2010 NoahDL88 said: Hi,I own a Subaru Leone with a Wrx EJ20G Motor in it, Competition gear box, Z4 Ecu with a stage 3 chip in it, Rear Wheel Drive. I need help in wiring a Data Link Connector, OBD I or OBD II, I have no idea which wire goes where to the ECU. Can I get some help with this please? Thanks, Regards, Amk. Now we can read it What year is your engine? that will determine if its obd 1 or obd 2 He's running an aftermarket ECU though, would it matter? Link to comment Share on other sites More sharing options...
Numbchux Posted April 16, 2010 Share Posted April 16, 2010 I don't know of any aftermarket ECU that can run a standard OBD diagnostics port. But they all have some way of communicating with a computer to monitor and adjust it. usually a Serial or USB cable. What are you trying to do? Link to comment Share on other sites More sharing options...
rxleone Posted April 16, 2010 Share Posted April 16, 2010 Numbchux said: I don't know of any aftermarket ECU that can run a standard OBD diagnostics port. But they all have some way of communicating with a computer to monitor and adjust it. usually a Serial or USB cable. What are you trying to do? He's right. I've never seen an aftermarket ECU with a trouble-code port like a standard ECU. They mostly all run the bog standard old-school printer-connecter style serial port right out of the ECU. Check it out. Link to comment Share on other sites More sharing options...
suberdave Posted April 16, 2010 Share Posted April 16, 2010 sounds to me like a stock Z4 ECU with a chip. not an aftermarket. should be able to hook up the stock Slect monitor cable. however, you would have to have a JDM slect monitor, that would read the Z4 ECU. not to mention that it may not comm. with a chiped ECU. Link to comment Share on other sites More sharing options...
