hi all
on a 97 legacy L Sedan
my friend has the same car as me and i am trying to find the horn relay wire that would complete the installation of a keyless entry system for them
i see that it is a yellow wire with a red stripe. and i really cant identify it easily. i figured i would find the relay and track down that wire from there.
thanks for any help
Look behind the dash, extreme left (driver's) side, above the fuse box. Pulling the lower dash panel may help.
The hot lead (coming from the fuse) should be a red/yellow (red wire with a yellow stripe). The other side of the relay coil (going to the horn switch) should be red/green. The relay output contact (going to the horns) should be red/blue.
