wrongturninwv Posted April 17, 2010 Share Posted April 17, 2010 2001 Leg Outback 3.0 H6. Need to know if the top pulley with the bearing inside that the main belt rides on that runs alt, power steering is interchangable with any other Subaru pulleys. Also if any of you have one let me know. thanks Link to comment Share on other sites More sharing options...
johnceggleston Posted April 17, 2010 Share Posted April 17, 2010 (edited) 2001 Leg Outback 3.0 H6. Need to know if the top pulley with the bearing inside that the main belt rides on that runs alt, power steering is interchangable with any other Subaru pulleys. Also if any of you have one let me know. thanks i sold some to grossgary for an h6 alt? / ac? belt tensioner. they may have used them in more than one place on the h6. i have some if you need them. let me know. 203-ff, bearing also NTN-6203LU, outside diameter: 40 mm inside diameter: 17 mm thickness: 12 mm sealed both sides http://www.ntnamerica.com/datasheet.asp?CO_PARTNOSEARCHTYPE=BEGINS&CO_PARTNO =6203&MANUFACTURER=NTN&BEARINGCATEGORY=RBSRD&CSEAL SHLD=Double-lip+contact+rubber+seal+one+side+(LU)&CL_PARTNO=62 03LU& Edited April 17, 2010 by johnceggleston Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 17, 2010 Share Posted April 17, 2010 That's a common 6203-2RS-C3. Any bearing house will have a stack of them for $5 each. GD Link to comment Share on other sites More sharing options...
CNY_Dave Posted April 19, 2010 Share Posted April 19, 2010 Napa has 'em, 6203-2rsj, easy-peasy to put 'em in. Tensioner pulley has a nut that likes to fall out in the back when you pull the bolt. Dave 1 Link to comment Share on other sites More sharing options...
