1998 Legacy Brighton wagon - worth fixing?
1998 Legacy wagon L, 155K miles
Has a serious engine problem, basically I need a new engine. Something to do with the crankshaft, it won't even move at all unless warmed up for 10 minutes.
Found a low-miles 2.2L engine + tranny (under 40K miles on them) from a wreck for 800 FRNs, worth getting it? It's here:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280494787892&viewitem=&sspagename=STRK%3AMEWAX%3AIT
It's automatic and I would really prefer a manual however for best MPG. But the replacement tranny is very low miles, supposedly.
Edited by etc
It's definitely an engine issue. I had a mechanic take it apart. Something got loose inside and worn out, causing poor timing. No power while cold and takes 10 minutes to even move at all. Plus 13MPG.
I decided I don't really like the Brighton trim level (no tach, power anything, plus I want M/T)
I think the issue is that crank pulley bolt, there were numerous threads on it, including mine.
Yes, it's very possible to fix it and if you know how I suppose not a difficult fix.
It runs just fine when warmed up, just gets abysmal MPG.
I should have it available in a few weeks.
Has a new radiator plus I have the OEM water pump/timing belt parts in a box.
Sending you a PM.
Edited by etc
