backcountrycrui Posted April 20, 2010 Share Posted April 20, 2010 So, 86 gl wagon, passenger side of the engine. Near the egr valve. There is a vacume line with a "T" in it, mine is closer to the passenger fender than the EGR but not by much. ON the underhood diagram it shows the hose, but it dosent say where it goes. Not in the chiltons either. Any guess? Thanks guys Mike Link to comment Share on other sites More sharing options...
Turbone Posted April 20, 2010 Share Posted April 20, 2010 When are you working? I can stop by. Link to comment Share on other sites More sharing options...
capn_r Posted April 20, 2010 Share Posted April 20, 2010 I've got an 86 FSM if anything from it would help. I don't know if the vacuum diagrams are the same as under the hood but I guess even if they are if I scanned them they would be larger so possibly a little clearer. Link to comment Share on other sites More sharing options...
backcountrycrui Posted April 20, 2010 Author Share Posted April 20, 2010 When are you working?I can stop by. Thanks rob, but I only work at the parts store once a month or so now. Just enough to keep my discount. Im back at the railroad, finally. I have to go to the Tacoma yard on tuesday ( tomorow) to do some radio control train stuff. Maybe I could give you a call when I am done? Should be sometime between two and five pm. I would apreciate it, and you could see my new hella's. I have the lights mounted just not wired yet. Mike I've got an 86 FSM if anything from it would help. I don't know if the vacuum diagrams are the same as under the hood but I guess even if they are if I scanned them they would be larger so possibly a little clearer. I dont think that there is a great deal of difference from 86 to 87, so a scan would be PERFECT if you have time. Thank you Mike Link to comment Share on other sites More sharing options...
MilesFox Posted April 20, 2010 Share Posted April 20, 2010 is the vacuum canister hooked up? the "T" goes between the intake manifold and the egr solenoid, and then to the vac canister. on automatic trans, it splits off to the bellhousing for the vac modulator. Link to comment Share on other sites More sharing options...
Turbone Posted April 20, 2010 Share Posted April 20, 2010 I have a 86 FSM at the house here, just give me a call before dropping by. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 21, 2010 Share Posted April 21, 2010 (edited) There is a Vacuum Line (3/16" hose) that comes from the intake manyfold and goes back to the Passenger's side fender nearby the area under the Windshield's base and it has the "T" which one of its ends (3/16" hose) goes to the White Vacuum Canister and the other end (1/8" Hose) goes nearby that, to an electric solenoid valve. the "T" main end (3/16" hose) "Powers" the Vacuum activated Air Conditioner Push Button Switches inside, thru the Vacuum Canister; the other end (1/8" hose) goes again back to the Engine Thru that electric Solenoid, to "Power" the Idle Accelerator when the Air Conditioner is Powered ON. I Hope this can Help... Kind Regards. Edited April 21, 2010 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
