need some ideas.
Car is an 88gl 5sp d/r
It has developed a wild problem. It idles pretty good but if you give it throttle over 2500 it sounds like a diesel with the jake brake on. I have
checked timing belts (deadon)
put in a known good coil and igniter.
put in a known good distributor
used but good fuel pump. old one had 5lbs of pressure.
car is a spfi. Some good points I haven't tried yet.
fuel filter
plugs and wires.
also tried another computer.
no codes showing.
Sure could use this car.
Edited by ellets
fuel filter
plugs and wires.
no codes showing.
hi, what type fuel system, does it have those chunky square valve things on the EGR system, mounted near the rear of the heads ? they go bad , leak exhaust gasses internally and cause similar problems, the exhaust gasses can go where they should not.
