kurt Posted April 22, 2010 Share Posted April 22, 2010 need instructions for replacement of bulb for driving light Link to comment Share on other sites More sharing options...
Legacy777 Posted April 23, 2010 Share Posted April 23, 2010 Kurt, Welcome to the USMB. I don't have any specific instructions for you. However, have you looked in your owner's manual to see if there are instructions provided? Link to comment Share on other sites More sharing options...
hflier Posted March 12, 2013 Share Posted March 12, 2013 Kurt, The 2006 subaru tribeca driving light are the low beam headlights. Check your lights, both high and low beam. If they work the light bulbs are all right. Then, turn off your headlights, but turn on your ignition. With the headlight switch off, and the ignitions switch on - the low beam head lights should be turned on to about 1/2 brightness. If you don't have the drl lights working, then check fuse 18 under the dash. Also, check the DRL relay that is under the dash. If that isn't the problem, then try a new DRL module that is under the dash. Link to comment Share on other sites More sharing options...
