Loyale93v Posted April 22, 2010 Share Posted April 22, 2010 Hello Everyone! My 1999 Legacy Brighton Wagon Is In Need! The Inside Drive Belt Tensioner is Stripped causing the the belt to get loose, very loose. Is there any after market shops That will sell me The Tensioner Assembly That I Need?! How Much Should It Cost? Is The Jusk Yard a Viable Option?? Thanks In Advance to all Who Reply! -Loyale93v Quote Link to comment Share on other sites More sharing options...
Mike104 Posted April 22, 2010 Share Posted April 22, 2010 (edited) Try Here: http://napaautoparts.com/Search/Results.aspx?Ntt=tensioner&Ntk=Keyword&N=599001+101999+50068+2068008 There are two styles, not sure which one you have. Here is one from O'Reilly: http://www.oreillyauto.com/site/c/detail/GATU/T43138.oap?year=1999&make=Subaru&model=Legacy&vi=1444343&forcedVehicle=true&pt=02378&ppt=C0141 OEM one from Online dealer is cheaper: https://www.subaruonlineparts.com/oempartscat.html $103.47 + Shipping Edited April 22, 2010 by Mike104 Quote Link to comment Share on other sites More sharing options...
svxpert Posted April 22, 2010 Share Posted April 22, 2010 Hello Everyone! The Inside Drive Belt Tensioner is Stripped causing the the belt to get loose, very loose. -Loyale93v how was it stripped? did you strip out the threads on the mounting holes? these dont just strip. plus if your belt got loose, chances are you damaged the valves or pistons on the engine. Quote Link to comment Share on other sites More sharing options...
Loyale93v Posted April 23, 2010 Author Share Posted April 23, 2010 how was it stripped? did you strip out the threads on the mounting holes? these dont just strip. plus if your belt got loose, chances are you damaged the valves or pistons on the engine. Let me be clear: the "drive belt" tensioner, not the Timing belt tensioner. I thought I was clear on that. My apologies if I wasn't. I am referring to the Accessory Drive belt that connects the A/C Compressor to the Crank Pulley. This is The Drive Belt closest to the Block. It has the A/C, The Crank Pulley & the Tensioner itself in the loop only. The 5 inch long bolt(10mm) that threads through the plastic housing that raises and lowers the tensioner pulley to tighten or loosen the accessory Drive belt Is stripped and will need replacement. I was able to loosen the pulley and then push and hold it down with a pry bar, while I tightened the bolt on the pulley. This helped a little but it won't last long. So I am trying to find one I can order over the net. Any one know where it could be found? Thanks to all who replied...and again, sorry for the mis-understanding. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 23, 2010 Share Posted April 23, 2010 The threaded plastic peice is like $6 from the dealer. You don't need the whole assembly - just the plastic tensioner nut. GD Quote Link to comment Share on other sites More sharing options...
Mike104 Posted April 23, 2010 Share Posted April 23, 2010 (edited) My bad! Read tensioner and got target fixation. See post below Edited April 23, 2010 by Mike104 Quote Link to comment Share on other sites More sharing options...
Mike104 Posted April 23, 2010 Share Posted April 23, 2010 (edited) Item 18 by chance? 73134AC001 - Adjust bracket http://www.subaruonlineparts.com/ $4.82 + shipping Local dealer (if they aren't 100 miles away) may be better option. Looks like that part # is used across a number of models Edited April 23, 2010 by Mike104 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 23, 2010 Share Posted April 23, 2010 Most of the dealers stock them since they are so commonly stripped. As noted it's probably not worth saving $2 by ordering online only to spend $5 getting it shipped. Local dealer is right around $6 for that part for me. GD Quote Link to comment Share on other sites More sharing options...
