keltik Posted January 8, 2011 Author Share Posted January 8, 2011 Yup, the EJ22 is fitted and running perfectly. Using a Weber 32/36 mated to a modified EJ18 manifold. Am also using a 1996 FWD Impreza gearbox which has the correct spline count for the EA81 front half shafts. The gear linkage worked fine and i made up a custom clutch cable. Have built a custom exhaust for it, added some wheels, done a little bit of tuning and once again have a running car. http://www.youtube.com/watch?v=4XIWzcWpZg8 Next battle is to fix up a couple small rusty spots and lower it. Quote Link to comment Share on other sites More sharing options...
LeoneTurbo Posted January 8, 2011 Share Posted January 8, 2011 Nice! What did you use for ignition (distributor etc)? Quote Link to comment Share on other sites More sharing options...
keltik Posted January 8, 2011 Author Share Posted January 8, 2011 Used a distributor from a EJ18 and im still using the EA71 coil. All seems to be working nicely Quote Link to comment Share on other sites More sharing options...
