tturnpaw Posted April 28, 2010 Share Posted April 28, 2010 I got pretty carried away doing the swap on the GL. I removed the alt harness too early on and I don't have any diagrams to help me install it. It's running as of now but I need to tie in the alternator to the car. I know the alt post puts off just over a volt but the 3 terminal connector on it I would like to connect and to the charge light on the car. Any help would be appreciated! Thanks numbchux for the writeup and help! Link to comment Share on other sites More sharing options...
bratsrus1 Posted April 28, 2010 Share Posted April 28, 2010 Hi This is Jerry, i have a early legacy alt. and wiring set up that will plug into your car. Make me an offer, i live in Selah on the other side of the mountains. Call me 1-509-952-2855 Thanks Jerry Link to comment Share on other sites More sharing options...
Numbchux Posted April 28, 2010 Share Posted April 28, 2010 can't help unless you tell us what the EJ donor was. there are a number of different alternators and wiring. Link to comment Share on other sites More sharing options...
tturnpaw Posted April 29, 2010 Author Share Posted April 29, 2010 It came out of a 90 legacy. It's being powered by a 92 legacy 2.2 harness Link to comment Share on other sites More sharing options...
Numbchux Posted April 29, 2010 Share Posted April 29, 2010 a quick searched turned up this: http://www.ultimatesubaru.org/forum/showthread.php?t=97148 1 Link to comment Share on other sites More sharing options...
Gloyale Posted April 29, 2010 Share Posted April 29, 2010 Yellow wire get's switched power Black/white wire goes to the charge light (white/red in the EA harness) Fatty white wire in the plug should be direct to battery, same wire as the bolt on one. Link to comment Share on other sites More sharing options...
