Mr. Brat Posted April 29, 2010 Share Posted April 29, 2010 Motor is and is now my DD again. But seems that everytime the brat sits for a long period of time (all night or after work). It is hard to start. Can hear the fuel pump running and shuts off like its suppose to. Also every once and while it doesn't like to start back up after running (getting coffee). Any suggestions? I was thing maybe a vaccum problem, but everything else works just fine. Link to comment Share on other sites More sharing options...
capn_r Posted April 29, 2010 Share Posted April 29, 2010 Do you have the wire from the B56 connector from the ecu (plug C terminal 10) connected to the start circuit? Link to comment Share on other sites More sharing options...
Numbchux Posted April 29, 2010 Share Posted April 29, 2010 ^yep also, have you tried letting the fuel pump prime a couple times before starting it? Link to comment Share on other sites More sharing options...
Mr. Brat Posted April 29, 2010 Author Share Posted April 29, 2010 I would say no to the wire connected to the fuel circuit, being I dont remember hooking that one up. I will start there. I am guessing that gets hooked to the starter relay? And yes I have tired and still do prime the pump (key on, crank, key off, and so on till it starts). Some days are better then others. This morning was a bit longer than normal. Hense the post this morning. Thanks guys Link to comment Share on other sites More sharing options...
backwoodsboy Posted April 29, 2010 Share Posted April 29, 2010 Its been a couple years since my last EJ swap, but there was a wire that would "choke" the engine for starting purposes while cranking.... Enrich the fuel mixture or whatever. I think that may be what were talking about up there ^^^^ ...anyway, I found that I needed to have that wire UN-hooked for warm or hot starts. The engine would flood itself with it hooked up. I disconnected it for the warm and hot starts and no more troubles! Toggle switch FTW Link to comment Share on other sites More sharing options...
Numbchux Posted April 29, 2010 Share Posted April 29, 2010 backwoodsboy said: Its been a couple years since my last EJ swap, but there was a wire that would "choke" the engine for starting purposes while cranking.... Enrich the fuel mixture or whatever. I think that may be what were talking about up there ^^^^ ...anyway, I found that I needed to have that wire UN-hooked for warm or hot starts. The engine would flood itself with it hooked up. I disconnected it for the warm and hot starts and no more troubles! Toggle switch FTW that's....not normal. I wonder if you were having a problem with the coolant temp sensor for the ECU. Link to comment Share on other sites More sharing options...
renob123 Posted May 2, 2010 Share Posted May 2, 2010 Just so the OP doesn't think he's crazy, my Brat has been doing something similar. It starts fine in the morning, but for example, when I try to start it after filling up at the gas station, it doesn't start easily. My ignition/ecu wire is hooked up, btw. You can really tell when you try to start it without. Mr. Brat, if you find what it is, be sure to post. I'll do the same:-) Jacob Link to comment Share on other sites More sharing options...
Mr. Brat Posted May 3, 2010 Author Share Posted May 3, 2010 So I hooked up pin 10 of connetor B56 to the start circuit (10-14 volts when starting only). Left the brat in the shop all night, started it this morning and it started right up just fine. From what I can tell it fixed it, I will park it outside tonight and see what happens. Thanks for the help! Link to comment Share on other sites More sharing options...
renob123 Posted May 3, 2010 Share Posted May 3, 2010 Mr. Brat said: So I hooked up pin 10 of connetor B56 to the start circuit (10-14 volts when starting only). Left the brat in the shop all night, started it this morning and it started right up just fine. From what I can tell it fixed it, I will park it outside tonight and see what happens. Thanks for the help! How are your starts after stopping for just a few minutes? Mine starts fine every morning, but when I go to the gas station or get coffee or something, it takes a long time to start up when I get back. Jacob Link to comment Share on other sites More sharing options...
Mr. Brat Posted May 3, 2010 Author Share Posted May 3, 2010 Started right back up. Maybe one revolution of the motor if that. Link to comment Share on other sites More sharing options...
Numbchux Posted May 3, 2010 Share Posted May 3, 2010 renob123 said: How are your starts after stopping for just a few minutes? Mine starts fine every morning, but when I go to the gas station or get coffee or something, it takes a long time to start up when I get back. Jacob check your coolant temp sensor. maybe the ECU is thinking the engine is cold. Link to comment Share on other sites More sharing options...
Mr. Brat Posted May 7, 2010 Author Share Posted May 7, 2010 Reno- Any luck with getting your problem figured out? Link to comment Share on other sites More sharing options...
renob123 Posted May 7, 2010 Share Posted May 7, 2010 Mr. Brat said: Reno- Any luck with getting your problem figured out? I had to replace the throw out bearing, so the Brat's been on jackstands for a week. I'll be driving it at least 600 miles this weekend, so I'll have a better idea then. Maybe I can actually get out the voltmeter when it's not starting and see what the CTS is doing. Jacob Link to comment Share on other sites More sharing options...
tturnpaw Posted May 10, 2010 Share Posted May 10, 2010 just so you know renob, (lol) cts on phase 1 ej22s are very common to fail. in fact, i own a 92 turbo legacy and im on the legacy central forum, and most issues with ej22s and ej22t's are the ect sensor. I also had to replace mine in fact. I suggest you get an oem one, but anything works. Link to comment Share on other sites More sharing options...
renob123 Posted May 10, 2010 Share Posted May 10, 2010 tturnpaw said: just so you know renob, (lol) cts on phase 1 ej22s are very common to fail. in fact, i own a 92 turbo legacy and im on the legacy central forum, and most issues with ej22s and ej22t's are the ect sensor. I also had to replace mine in fact. I suggest you get an oem one, but anything works. Yeah, I read a bunch of stuff in the New Gen forum here about it, and since it's the cheapest fix, I'll take a shot at it. I try to search legacycentral sometimes, but its search system and I don't get along. I'm pretty good at searching for stuff, but that thing seems to return threads that don't have my keywords in it:confused: Jacob Link to comment Share on other sites More sharing options...
