EastCoastEJ22T Posted April 30, 2010 Share Posted April 30, 2010 (edited) My old faithful 95 2.2 4eat lego, is slowly rotting away. Still runs like a champ, burns no oil, throws no codes......gotta love the 2.2's. I've located a 2000 outback with a snapped timing belt, low miles, good body. Is it possible to swap the 2.2 from my 95 into the 2000 shell? I am a very capable mechanic and don't expect it to be plug and play. Just need to know if it will be worth my while. cheers, Ian Edited April 30, 2010 by EastCoastEJ22T Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted May 2, 2010 Share Posted May 2, 2010 It would swap over. Not sure how the electronics/electrical side will cooperate. You may need address that. Other thought is the 2000 outback is going to be heavier than your 95, and may feel a little less "peppy" than your 95 did. Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted May 2, 2010 Share Posted May 2, 2010 There will be more holes on the transmission side (6) compared to four on your engine. As far as the electrical goes, you will need some serious work. I have not read that anyone has invested the time to do it. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 2, 2010 Share Posted May 2, 2010 There's lots of issues with this swap. You'll have to let us know what kind of job you're looking for. A basic swap this is not. A big project with some kinds along the way is more like it. That being said - if you're capable of this swap, you're more than capable of just fixing the engine that's in the 2000, go buy it tomorrrow, jump on that thing. I've yet to see in person, or on here, a Subaru with a broken timing belt that didn't just need some bent valves replaced. The motor is going to be fine. With it's propensity to blow head gaskets you'll want the updated gasket in there anyway. Fix it and you've got a great car. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted May 2, 2010 Share Posted May 2, 2010 As already written, there are serious electrical problems to over come that turn this into a nasty swap. Much electrical engine management systems was changed between 95 to 00 models. You could be stepping into a nightmare. You don't mention how many miles/km on existing 2000 motor, if less than 150K, then would elect to repair the 2000 motor. Head gasket problem on Gen 2 2000 model is not as serious an issue, as with the Gen 1 featured during 1996 to 1999. Since motor does not run, you should be able to buy this car on the cheap! Quote Link to comment Share on other sites More sharing options...
