The Beast I Drive Posted May 2, 2010 Share Posted May 2, 2010 Hey ya'll, I couldn't decide which would be the best forum for this question, but since its an off-road mod, I should ask here. Will .01 difference in gear ratio front to back be enough to burn up an early Legacy 5-speed viscous coupler if I drive it on the street alot? I ask because I have definite plans to put a straight axle under the rear of the Beast and run a 4.11 RX/EJ hybrid tranny, but the rear axle ratio is 4.10, not 4.11. I figure, if nothing else, it would be ok for off-road only, and trailer it to the trails, but would it really hurt it to drive it on the street? If nothing else, I could always fab a driveline disconnect to go where the carrier bearing is, but if I dont have to that would be nice... Axle in question is from a 90's Isuzu Rodeo Thanks -Bill Link to comment Share on other sites More sharing options...
monstaru Posted May 2, 2010 Share Posted May 2, 2010 word on the street is that 10% is an ok difference. so, 1% is definitely ok...... there are several posts about it at NW-WHEELERS...........thats where i get almost all of my hardcore info:grin:, and pirate4x4 of course. but there are a couple of guys running more than 1%..........and say that it is fine.... cheers, brian Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 2, 2010 Author Share Posted May 2, 2010 Thanks Brain, sounds like this project is a go then -Bill Link to comment Share on other sites More sharing options...
Qman Posted May 3, 2010 Share Posted May 3, 2010 Actually, a lot of old GM stuff ran 4.11-4.10. It is more than fine. Link to comment Share on other sites More sharing options...
Uberoo Posted May 3, 2010 Share Posted May 3, 2010 My dodge has 3:55's in front and 3:54's in the back or vice versa and it works fine.Although I can't have it in 4wd on anything like pavement though... something about transfer case wind-up around corners or something... Link to comment Share on other sites More sharing options...
Numbchux Posted May 3, 2010 Share Posted May 3, 2010 hold up, all your references (AFAIK) are part-time 4WD vehicles. little differences like that are fine off-road with a locked center. But that's not really applicable to a EJ VLSD AWD drivetrain. let's say you're running 30" tires. at 70mph, that's 784 rotations. 4.10 R&P = 3,214.4rpm 4.111 = 3,223 8.6 rpm difference at speed typically speaking, subarus can tolerate a max of 2/32s difference in tread depth. so that's 4/32s in overall tire diameter. stock WRX tire size of 24.87" = 945.42 rpm @ 70 * 4.111 = 3,886.6 that minus 4/32s is 24.75" = 950.19 = 3,906.2 19.6 rpm difference at speed. so...yea. you should be fine. Link to comment Share on other sites More sharing options...
idosubaru Posted May 3, 2010 Share Posted May 3, 2010 Nice hit Chux, that's what I suggested but it either got deleted or lost in cyberworld. Should be helpful too if anyone has similar questions of different ratios. Link to comment Share on other sites More sharing options...
