We have a 2001 Forester with 90K miles on it. It has gotten hot (not overheated) twice. Both times it blew out water in the overflow. The first time, I filled it with coolant mix and a new radiator cap and it was fine for 20K miles. The second time the upper rad hose was collapsed shut, the cap was holding a vacuum. Anyone else have cap problems?---Jack
The collapsed hose is a sign that the coolant is going somewhere.
I hate to say it, but you might take the cap off when its cold and look for bubbles in the coolant, sure sign of a blown head gasket.
A new Subaru OEM cap is cheap insurance though, throw a new one on and see if that makes a difference.
It has not used any coolant before or after and not overheated going over US 80 from Sac to Reno after I replaced the cap. The original cap had about 60K on it. Do aftermarket caps not work well on Subarus?
