Dissable Hillholder question
I have read past HH post still have questions.
When I take off the cable on my 87 GL 4WD, do I need to hook a return spring to the clutch cable?
Do I need to secure the top of HH part where the cable was disconected?
What is the correct bleeding
LF RR RF LR
OR
RR FL LR RF
If I keep the HH conected, do I need to hold down the clutch then pump the brakes?
Return spring for no HH: Yes. Some DL's had them so you can actually order them from the dealer. Nothing needs to be done to the HH - just leave it alone (sans cable).
You do not hold the clutch down while bleeding. The HH does nothing *unless* you push on the clutch. It's a straight shot through the HH if you don't press the pedal.
Correct order is MC, then either rear wheel - then the opposite front. Then the other rear and the opposite front. The order that you do the circuits in doesn't matter - just so long as you do the farthest from the MC first and then the other wheel on that same circuit before moving on.
