Bash Posted May 4, 2010 Share Posted May 4, 2010 I have read past HH post still have questions. When I take off the cable on my 87 GL 4WD, do I need to hook a return spring to the clutch cable? Do I need to secure the top of HH part where the cable was disconected? What is the correct bleeding LF RR RF LR OR RR FL LR RF If I keep the HH conected, do I need to hold down the clutch then pump the brakes? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 5, 2010 Share Posted May 5, 2010 Return spring for no HH: Yes. Some DL's had them so you can actually order them from the dealer. Nothing needs to be done to the HH - just leave it alone (sans cable). You do not hold the clutch down while bleeding. The HH does nothing *unless* you push on the clutch. It's a straight shot through the HH if you don't press the pedal. Correct order is MC, then either rear wheel - then the opposite front. Then the other rear and the opposite front. The order that you do the circuits in doesn't matter - just so long as you do the farthest from the MC first and then the other wheel on that same circuit before moving on. GD Link to comment Share on other sites More sharing options...
