dragonflysix Posted May 5, 2010 Share Posted May 5, 2010 i droped a valve seat had the heads rebuilt in an 85 gl wagon. when i disassembled the heads i did not keep the cam follower's or the lifters in order. is this going to flat spot the cams like a pushrod motor or no worries? Link to comment Share on other sites More sharing options...
Qman Posted May 6, 2010 Share Posted May 6, 2010 It could. Link to comment Share on other sites More sharing options...
Gloyale Posted May 6, 2010 Share Posted May 6, 2010 But it probably won't I've assembled these motors "mix n match" style before without noticing any trouble. You are more apt to have a problem getting oil pressure to the HLAs than with the Cam followers. Make sure you replace the Cam Case O-ring and you've got a good oil pump with fresh seals. Link to comment Share on other sites More sharing options...
markjw Posted May 6, 2010 Share Posted May 6, 2010 If the follower has a flat spot worn into it already,it may cause problems. If you can't detect any wear on the follower with your finger,you should be fine. Link to comment Share on other sites More sharing options...
