aiiadict Posted May 5, 2010 Share Posted May 5, 2010 water in both cylinders on passenger side of vehicle. I pulled the manifold and head and could not find any obvious problems.. mating surface of head isn't %100 flat, varies about 1mm. there is no water in oil. the intake port on the head does NOT show rust (rusty water in cooling system) the head was put on with gasket + formagasket, torqued properly. at one point I tried to start the vehicle and it had vapor lock. no signs of steam in exhaust. I pulled the plug, cranked the water out, ran it. next time I tried to start it, vapor lock. Seems like water is leaking into the head when engine is sitting, off. any ideas? Rich Link to comment Share on other sites More sharing options...
NoahDL88 Posted May 5, 2010 Share Posted May 5, 2010 1mm on a cylinder head is like climbing Everest Could be a cracked head? Link to comment Share on other sites More sharing options...
aiiadict Posted May 5, 2010 Author Share Posted May 5, 2010 NoahDL88 said: 1mm on a cylinder head is like climbing Everest Could be a cracked head? I see 1 crack in the head, in the exhaust port. The aluminum comes to a "peak" in the center of the port, where the exhaust passages meet. The crack does not appear to go very deep, and I don't see how water could be getting in cylinder from there.. Where should I look for cracks? Remove the valves and look under them? should there have been obvious signs of a leak on the intake manifold gaskets? same for sign of leak on head gasket? I couldn't find any signs of a leak, but don't know if there would be. Could water somehow come through cylinder walls? I put the pistons on bottom dead center and feel with my fingers, they're smooth. you say 1mm is too big a variance on mating surface? Ok, I'm going to either have this one machined or get a new (used) head. Rich Link to comment Share on other sites More sharing options...
NoahDL88 Posted May 5, 2010 Share Posted May 5, 2010 a crack between the intake and exhaust valves is usually nothing to worry about. every head I've taken off has had that crack with no issues. Its hard to diag over the internet, I'd see if you can find a new head, and go from there. I'm not 100% but the solid and hydraulic lifter heads may be different, so you may have to make sure you get the right one. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 5, 2010 Share Posted May 5, 2010 (edited) 1mm is INSANELY warped. But if you aren't using a machinist's rule that's been surface ground flat to measure the flatness then it's not a valid measurement. Most things we take as flat in daily life (even a metal machinists square for example) are not flat enough to use as measureing insturments. The allowable warpage for a cylinder head is about .005", which is about 0.125mm, or approximately 1/8 as much as you measured. If they truely are warped by 1mm then you will have to throw them away. You can't grind them enough to correct that. .020" is the max you can take off per the spec and that's only going to get you 1/2 of where you need to be. But again - I doubt your measurement and your insturments as I have never encountered one that warped. If I did I would throw the whole engine the scrap pile because the amount of abuse it took to get that screwed up would make it an unwise investment. The leakage was probably a bad manifold gasket although you say you used formagasket on the head gasket? . That's a no-no and also a probable failure point. Head gaskets are installed 100% dry on Subaru engines. Always. GD Edited May 5, 2010 by GeneralDisorder Link to comment Share on other sites More sharing options...
aiiadict Posted May 5, 2010 Author Share Posted May 5, 2010 aiiadict said: water in both cylinders on passenger side of vehicle. more information: I actually measured variance in level of mating surface, it is about .005 inches. Is this ok? I pulled the valves out. I could see where water had obviously been pooled up in the intake port (rust marks on back of intake valves indicate water level)... There was a bit of rust on the back side of the exhaust valve. The crack that I had seen before is actually a mark from the mold during manufacturing. I cannot see any cracks in the intake or exhaust ports. I'm beginning to think it must have been a leaky manifold gasket (although no rust marks in intake port on top of head, just rust on back side of intake valves) I'm thinking I'll put a new head gasket, new manifold gaskets, and put it back together and see if all is well. I double checked the oil at the dipstick, it looks like oil. Would I be able to see water in the oil if engine hasn't run in about 12 months? IE does it need to be churned up to see the water? any more advice? Rich Link to comment Share on other sites More sharing options...
aiiadict Posted May 5, 2010 Author Share Posted May 5, 2010 forgot to mention: I have never got this engine over about 200 degree F. It has reconditioned heads, new bearings, new rings. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 6, 2010 Share Posted May 6, 2010 Rust will not form in the presence of coolant - the glycol solution will inhibit rust formation so looking for rust marks is probably not going to tell you much. I agree - put it back together with dry head gaskets, and OEM manifold gaskets (torque to 12 ft/lbs). GD Link to comment Share on other sites More sharing options...
987687 Posted May 6, 2010 Share Posted May 6, 2010 aiiadict said: more information: I actually measured variance in level of mating surface, it is about .005 inches. Is this ok? I pulled the valves out. I could see where water had obviously been pooled up in the intake port (rust marks on back of intake valves indicate water level)... There was a bit of rust on the back side of the exhaust valve. The crack that I had seen before is actually a mark from the mold during manufacturing. I cannot see any cracks in the intake or exhaust ports. I'm beginning to think it must have been a leaky manifold gasket (although no rust marks in intake port on top of head, just rust on back side of intake valves) I'm thinking I'll put a new head gasket, new manifold gaskets, and put it back together and see if all is well. I double checked the oil at the dipstick, it looks like oil. Would I be able to see water in the oil if engine hasn't run in about 12 months? IE does it need to be churned up to see the water? any more advice? Rich If you think there's water in the bottom of your oil pan, DON'T RUN IT! Drain the oil and put fresh oil in. You should after sitting for 12 months anyway. Link to comment Share on other sites More sharing options...
aiiadict Posted May 11, 2010 Author Share Posted May 11, 2010 GeneralDisorder said: I agree - put it back together with dry head gaskets, and OEM manifold gaskets (torque to 12 ft/lbs). GD I ordered and received a new head gasket. Interesting, this is very different than the first gasket I put on... the first (which appears may have leaked, or it may have been manifold gasket) was flat black colored, looked kind of like charcoal. It felt rough/uneven surface. the one I just bought is deep dark red/brown, shiny surface, feels like soft rubber coating. Link to comment Share on other sites More sharing options...
