Walker Valley Time
Scott in Bellingham
Bump
Come on, guys...Scott's been itching to go out again, after half or more of NWOG decided to rebuild their rigs at the same time!!!
I only need exhaust work, rear axles, and ECU containment to wheel again. :banana:
Me Rick and Woody are still all building or rebuilding our rigs, so we are out. Yohn has 15 broken axles on his rig and needs new ones................
I'm out, till mid June or late June for work anyways, unless it is raining hard...................... Sundays are the only day for me right now and even those are questionable.....................
Jeff
maybe up for an easy trail ride, new to area and would like to meet up with some of you around here. I know im going to need a cup for my rear axle, the one i started rebuilding is cracked... anyone have an extra? and change my shock mounts. overextending. but that will porobly wait a bit... let me know-
Walker is hard the the subbies, will need lift , tires and a locked rearend
Jeff
Huummm thats to bad , glad you have work tho
am going to install the dual range trans tomorrow, so hopefully I can get it all figured out very soon and drivable again!! :)
then we can go play! :banana:
Awesome are you ready for body damage?
